Brax X1400 blown fets. Help.
Old 3rd December 2012, 03:53 PM   #31
evianamp2011 is offline evianamp2011  United States
evianamp2011's Avatar
Ok. Am going to order the fets today and pick them up. I'll order a 2525a ic, just in case.
Old 6th December 2012, 03:47 AM   #32
Ok, got the new fets in and gate resistors. I powered it up but notice that the gets (both audio & ps) where getting pretty warm real quick. I don't have mounted to the chassis, so i powered it right off. Will mount it with new compound between the sinks.
Oh i also switch the insulators to mica, because the one if the originals had a small tear and i didn't want to risk it.
Old 6th December 2012, 07:57 AM   #33
Perry Babin is offline Perry Babin  United States
Is it possible that there was a fault in the audio section of the amp before they reversed the power connections?
Old 6th December 2012, 01:23 PM   #34
Don't know because once i put it back in the chassis i didn't notice any heat problems. I feed it signal and checked it with my scope.... I only got 16.6vac prior to clipping on each channel. Shouldn't i be getting more like in the 24v area? I didn't have a load on the channels.
I got 1 millivolt dc offset on the channels, when powered on with no load or/and signal. I plan on using some 2 way comps to see if it has any higher voltage or if it gets hot.
I have a 10 amp fuse on the b+ and it didn't blow it.
Old 6th December 2012, 02:50 PM   #35
According to the owners manual, its only 50watt x 4 at 4 ohms and 100 x 4 @2 ohms so i guess the voltage i got last night was just right for their power ratings.
Can't wait to listen to it.
Old 11th December 2012, 01:08 AM   #36
Tested and functions properly. Got approx 60 per ch at 4 ohms. Shipped it back to my friend. Thanks Perry and Cecil.
Brax X1400 blown fets. Help.Hide this!Advertise here!
Blown parallel FETs? Yooper Power Supplies 3 21st October 2012 01:06 AM
Autotek Super Sport At2000.1 blown psu fets substitude ivkata Car Audio 2 17th April 2012 04:26 PM
Rockford Fosgate 60ix FETs blown LazySteve Car Audio 12 23rd June 2011 09:48 AM
Brax, Helix Schematic senee Car Audio 2 1st February 2008 06:42 PM
Brax amplifier help (no output) MCD007 Car Audio 10 10th January 2008 09:33 PM
