Brax X1400 blown fets. Help.
Old 1st December 2012, 08:16 PM   #21
Perry Babin is offline Perry Babin  United States
I wouldn't try removing that part just yet, Unless the holes are very large around the wires, it may be very difficult to get back in.
Since the leads are so short, it would be very difficult to get it back in if there is something on top of the board to make it stand off more than it does now.
One alternative may be to run wires from the top of the ground terminal to the top of the power stabilizer ground terminal using ring terminals at the blocks.
Old 1st December 2012, 09:57 PM   #22
evianamp2011 is offline evianamp2011  United States
evianamp2011's Avatar
Yeah if there is space for it, that's what I'll do. The only reason i would want to remove the unknown component is to make sure there's no other damaged traces. It seems its just the ground thats open, but you never know.
But as you stated it its pretty risky removing it and not being able to solder it back on, so it does worry me.
I'll keep the kapton film "trick"in mind that's what I'll have to do just to prevent any short of shorts. Should i be worried about the IC's, would they be likely damaged due to the user mistake?
Old 1st December 2012, 10:07 PM   #23
It's possible that the primary-side ICs were damaged but you can check them when you pull the FETs. Temporarily jump the ground and power up the amp. Does the 494 produce a clean square wave on pins 9 and 10 (assuming that pins 8 and 11 are connected to B+)?
Old 1st December 2012, 10:15 PM   #24
Okay I'll remove the fets and temporary jump the ground terminals. I'll check the wave forms tonight it as soon as i get a chance.
Old 2nd December 2012, 03:38 PM   #25
KOk i remove the fets. But i was looking closer at the unknown component and i believe is a transformer and if i do as you (Perry) say then I'll be bypassing it. Don't know if its okay to bypass it or not.
Below is a pic showing the traces below the unknown component. All ground pins had continuity between them as well as the positive.
Old 2nd December 2012, 04:01 PM   #26
I think that they are a group of inductors. If so, bypassing them won't hurt anything, especially not for testing. It's not likely to be a transformer because there is nothing to drive it.
Old 2nd December 2012, 04:17 PM   #27
OK. I'll power it up and check the ic's.
Perry this amp uses the sg2525a and right next to it is one label"6n137" its an 8 pin ic.
Old 2nd December 2012, 09:25 PM   #28
The outputs on the 3525 are pins 11 and 14.
I don't know whey they're using the opto-coupler.
Old 3rd December 2012, 02:14 AM   #29
Sorry it took me long, but here are the wave forms i got. Both pins 11 & 14 looked identical.
My scope was set at 2v/div & 20us time/div.
Pin 11
Pin 14
Let me know what else to check for.
Old 3rd December 2012, 05:21 AM   #30
They look OK but in the future, leave your scope set to DC coupling. Read the 'best initial setting' section of page 73 of the web site.
Brax X1400 blown fets. Help.Hide this!Advertise here!
Blown parallel FETs? Yooper Power Supplies 3 21st October 2012 12:06 AM
Autotek Super Sport At2000.1 blown psu fets substitude ivkata Car Audio 2 17th April 2012 03:26 PM
Rockford Fosgate 60ix FETs blown LazySteve Car Audio 12 23rd June 2011 08:48 AM
Brax, Helix Schematic senee Car Audio 2 1st February 2008 05:42 PM
Brax amplifier help (no output) MCD007 Car Audio 10 10th January 2008 08:33 PM
