Orion Colbalt 2100 - Page 7 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 8th December 2012, 06:54 AM   #61
from #1 leg transistor to the other #1 leg transistor 2nd one im getting 94.9 on the hot side and
95.0 on the good side
Old 8th December 2012, 07:05 AM   #62
Did you play it long enough when you swapped transistors from the other side to know if it was getting hot?
Old 8th December 2012, 07:15 AM   #63
no i didnt long enough to know it was playing cause before all this there was no sound coming from the channel when it was blown so i figured when i swapped them it was playing it was working
Old 8th December 2012, 07:18 AM   #64
also i noticed when i hooked up the left and right inputs (RCA'S) with the speakers disconnected now the transformer coil is whinning
Old 8th December 2012, 07:20 AM   #65
actually id say it sounds more like a trickling sound
Old 8th December 2012, 07:25 AM   #66
I spent about 2 hours reworking the board and made sure all the solders were good for all the parts that looked like there was lacks of solder on the board add solder to alot of components making sure there was no shorts or open connections because my cobalt 230 had a sound channel out come to find out one of the resistor came detached off the board causing the whole channel not to work so i wanted to make sure everything had a good solder.
Old 8th December 2012, 08:54 PM   #67
I did tighten the transistors down where they were getting hot it takes longer to get hot but it still seems to be getting way to hot when the other side is nice and cool and nothing is hooked up when i tested the theory.
Old 9th December 2012, 01:40 AM   #68
Measure the resistance between the two legs of the adjacent 45N10s on the hot side. If you read ~0 ohms and still have significantly greater voltage across the resistor for one of the 45N10s, the 45N10 connected to the resistor that has the greatest voltage across it may be leaky. You'd need to remove it and check it carefully.
Old 9th December 2012, 01:59 AM   #69
are trying to tell me to measure the same legs of the 2 4510 transistors that are next to each one probe on the left leg of the one and the other probe on the left leg of the second 4510?
Old 9th December 2012, 02:01 AM   #70
Sorry. That should have read 'between the two source legs'.
Measure between the 3rd legs of the two adjacent 45N10s on the hot side.
orion 2100 HCCA amplifier trustyrusty10 Power Supplies 3 1st June 2010 01:31 AM
Anyone one with a heatsink for Orion 2250/2100 amc32 Car Audio 0 20th August 2009 08:04 PM
orion 2100 hcca mike49504 Car Audio 11 11th February 2008 02:14 PM
Orion 2100 wiring schematic jerebohner Car Audio 4 14th April 2007 12:43 PM
Need pictures of orion 2100 output?Please! shallowfu Car Audio 5 31st August 2006 07:37 PM
Copyright 1999-2017 diyAudio
