Orion Colbalt 2100
Orion Colbalt 2100
Old 1st December 2012, 09:26 PM   #11
Perry Babin is offline Perry Babin  United States
Yes. There are some amps that use all N-channel but an all P-channel would be extremely rare. I'm not saying that it's not possible, just unlikely. That's why I wanted you to check all 8 to make absolutely sure that all were the same.
Old 1st December 2012, 09:42 PM   #12
Exbass17 is offline Exbass17
After verifying the Chipsets you was right sorry about that 4 of them are (SMW45N10) Chips Great so now i need to match 4 of those and 4 of the (SMW20P10) Chips to a equal value any suggestions reason im assuming there all shot is cause im seeing quite a few resistors in line with each transititor that look internally burned (brown on the inside coating of the resistor color codes those are still visible tho i plan on swapping all those out as well which those all have the same value the ones that are burned it looks like strange only those burned for each chip).
Old 1st December 2012, 09:56 PM   #13
My intentions are to swap out all the Output transistors 2 types 8 chips total and also swap out the 0490-0210 chips for the power supply which there is 8 of those and swap out the the resistors which appear blown and hopefully i have a new amp but theres 3 types of transistors i need that would need to be cross referenced and all be balanced for the values of the amp any suggestions?
Old 1st December 2012, 10:04 PM   #14
Can you post clear photos of the burned resistors?
Old 1st December 2012, 10:14 PM   #15
I dont have acces to a good camera right now theres brownish color underneath the blue film there not black and the values are still visible but theres like 4 areas and there all inline with the transistors i might be able to capture them with my phone but i can promise how clear it would be i could capture some of the black spots on the amp as well for you tho so you can see what im working with it appears someone heated this thing up pretty bad i recieved it for parts which i decided i wanted to revive it if i could for 100$ cause i have a Cobalt 230 Amp as well just needs some work done to the right Channel im thinking just a transistor on that one as well
Old 1st December 2012, 10:39 PM   #16
If you need a camera for this type of work, the lowly Nikon Coolpix 2200 is a good choice (samples on the basic repair page). There are at least 2 on ebay right now. Both are less than $20 including shipping.
Old 1st December 2012, 10:56 PM   #17
Heres a photo of the resistors hopefully its clear enough for you
Old 1st December 2012, 11:06 PM   #18
Thanks for the info i may need one of those by the time on done i have 6 other amps i need to repair with bad transistors :-)
Old 1st December 2012, 11:14 PM   #19
I don't think that those indicate any problems. A lot of Orion amps have resistors that become discolored like that. If they're within tolerance, there's no need to replace them.
Did any of the 45N10 transistors fail?
Old 1st December 2012, 11:19 PM   #20
I just finished up running a ohm test on all of the chips including the power supply chips my ranges were for power 192-199 ohms and the channel transititors leveled out at around 227 ohm and one of the chips in the corner the SMW20P10 is beeping on my meter when i run a ohm/diode check arcross the outer legs so im assuming the ones shorting all the others had ohms and did not beep
Orion Colbalt 2100Hide this!Advertise here!
orion 2100 HCCA amplifier trustyrusty10 Power Supplies 3 1st June 2010 01:31 AM
Anyone one with a heatsink for Orion 2250/2100 amc32 Car Audio 0 20th August 2009 08:04 PM
orion 2100 hcca mike49504 Car Audio 11 11th February 2008 02:14 PM
Orion 2100 wiring schematic jerebohner Car Audio 4 14th April 2007 12:43 PM
Need pictures of orion 2100 output?Please! shallowfu Car Audio 5 31st August 2006 07:37 PM
