Orion Colbalt 2100
Orion Colbalt 2100
Old 10th December 2012, 03:12 AM   #91
Exbass17 is offline Exbass17
I noticed the little bi polar transistors im not sure if there the driver transistors but some were hot and some of them were cool but most of them where on the side of the hot transistors you had me test there was couple that were hot tho on the good channel or is that normal since the 45n10 transistors are getting hot?
Old 10th December 2012, 03:14 AM   #92
if you feel that the 45N10 transistors are bad i could always swap them with the good side and see if that fixxes the heat problem on that side if they begin heating up disconnect it right away to avoid more problems
Old 10th December 2012, 04:24 AM   #93
I swapped out the 45N10's from the cool side transistors and replaced them with the 2 transistors that were getting hot inlined with the 2 IRFp9140pbf transistors you suggested i use they seem to be slightly warm but not burning my fingers like the others were the bi polar transistors are still getting hot and when i connect my laptop signal to the amp the transformer coil start trickling
Old 10th December 2012, 04:26 AM   #94
also the transformer coil feels warm i dunno if thats normal
Old 10th December 2012, 06:06 AM   #95
Perry Babin is offline Perry Babin  United States
Please use real words. Dunno isn't a word. Please use proper punctuation.
Please explain precisely where the probes were on the transistor when you read 5.1v on it with the meter on diode check.
Old 10th December 2012, 07:13 AM   #96
_ _ - grd _ + = 5.10 volts / 5.25 Volts thats the volts I get on diode
check for transitor 1 and 2 that was hot each ( _ ) = pins from left to right
- and + = probe color
Old 10th December 2012, 07:17 AM   #97
as for the ohms i am not getting any ohm readings through out both of the transistor either way i probe them on the pins with the diode check set to ohms when I switch the meter to diode check/ volts setting that is when I get the 5.10V # 1 transistor #2 transistor 5.25V on the meter
Old 11th December 2012, 12:56 AM   #98
Post a photo of the probes on the transistor and the meter display when reading 5.1v.
What do you mean by not getting any ohms reading? Do you mean that you are reading infinite resistance or are you reading 0 ohms? You need to take the time to write in a way that can be understood. This isn't a chat room. This is technical and requires precise language.
I have no clue what post #96 means.
Old 11th December 2012, 01:19 AM   #99
The underscores are pins on the transistors from left to right and the voltage readings i got with the transistors i was having problems with. As for the when i have the ohms setting on the DMM diode check im getting OL when i do all the steps take to check the transistor on the Basic transistor testing for FET page you told me to look at
Old 11th December 2012, 01:41 AM   #100
You need to check with the meter set to ohms (highest range for non-autoranging meters) and diode check.
Orion Colbalt 2100Hide this!Advertise here!
orion 2100 HCCA amplifier trustyrusty10 Power Supplies 3 1st June 2010 01:31 AM
Anyone one with a heatsink for Orion 2250/2100 amc32 Car Audio 0 20th August 2009 08:04 PM
orion 2100 hcca mike49504 Car Audio 11 11th February 2008 02:14 PM
Orion 2100 wiring schematic jerebohner Car Audio 4 14th April 2007 12:43 PM
Need pictures of orion 2100 output?Please! shallowfu Car Audio 5 31st August 2006 07:37 PM
