Rockford Fosgate Punch 800.2 - Page 8 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 1st December 2012, 08:29 PM   #71
That should be OK.
Jump the transistor shown in the image below. Remove all jumpers from the 300 series channel and have all components installed in the 300 series channel.
Power the amp up through a current limiter. It will pull significant current initially but the current should drop off. Does the current drop to what you'd expect for this amp?
If so, does the 300 series channel work properly?
Old 1st December 2012, 08:58 PM   #72
seankane's Avatar
Originally Posted by Perry Babin View Post
That should be OK.
I jumped the transistor, and powered up through 2 20 watt 8 ohm resistors for a 4 ohm 40 watt limiter.
The amp powers up and didnt draw any current, it produces sound through that channel but is distorted.
If I remove the limiter and power up it draws 40 amps current and chatters.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 1st December 2012, 09:30 PM   #73
Do you have a lower value resistor? A 2 ohm dummy load would be good.
If you haven't confirmed that R318 is within tolerance, check it now.
Old 2nd December 2012, 12:44 AM   #74
seankane's Avatar
R318 is good.
I have an 80 watt 2 ohm load resistor.
Old 2nd December 2012, 06:37 AM   #75
See if it powers up and produces audio with the 2 ohm resistor, if not we'll have to go at this a bit differently. Reinstall the jumper on the bias transistor for the 300 series channel and re-check to confirm that the amp will produce clean audio from that channel.
Old 2nd December 2012, 07:51 PM   #76
seankane's Avatar
A couple of questions:
1: Leave the jumper wire on the transistor Q11 marked 2A?
2: Power the amp up with the 2 ohm 80 watt resistor in line with B+?
3: Check for audio without the jumper on the bias transistor first, then install the jumper again and re-check audio?
I checked for audio a few posts back with the 2 ohm resistor inline with B+ and it produces audio but very distorted.
I just want to be sure we are on the same page here.
Thanks Perry.
Old 2nd December 2012, 08:36 PM   #77
1: Yes, for now. It's produces less stress on the outputs.
2: Yes.
3: Leave the bias jumper on both channels for now.
Old 2nd December 2012, 09:34 PM   #78
seankane's Avatar
Before we get started again I found something I thought I would bring up.
I removed all jumpers.
I removed Q10 marked 1A the amp powers up fine and idles and produces audio but wont clip turns into the shark fin waveform eventually. The waveform is clean until that point that it does not clip. The outputs do not get hot either.
What is the purpose of Q10?
Is this important or do I re-install it and proceed with what you asked?
Old 2nd December 2012, 09:39 PM   #79
Q10 enables the biasing. It's similar to using the jumper across the C&E of the bias transistor but the jumper just disables the biasing at the drivers. Removing Q10 removes the biasing all the way back to the differential amplifier.
Old 2nd December 2012, 09:54 PM   #80
seankane's Avatar
OK all 3 jumpers installed, no current limiter just straight to the supply.
100Hz wave scope set to 2ms/20vd
1st pic is 3 series channel we have been working on clean audio, no heating fets, no current draw, idle is stable.
2nd pic is of the defective channel I originally posted that was all burned up, clean up until clipping, no heating fets, no current draw, stable idle. I am sure this channel has some defective components because of the burned source resistors, but one channel at a time and to figure out why this amp cant enable the outputs without the jumpers would be the most important.
Thoughts?
rockford fosgate punch 800 a2 ernie cosillos Car Audio 3 12th June 2011 01:41 AM
Fosgate Punch 800 a4, diagram needed camoandbee Tubes / Valves 0 13th April 2011 06:33 PM
Rockford Fosgate 800.2 Brain Fried Car Audio 2 16th April 2010 05:14 PM
rockford fosgate punch z stevena2006 Car Audio 2 23rd December 2009 04:20 PM
Rockford Fosgate Power 800.4 lostamps Car Audio 6 2nd January 2008 12:21 PM
Copyright 1999-2017 diyAudio
