Rockford Fosgate Punch 800.2
Old 1st December 2012, 06:55 AM   #61
Perry Babin is offline Perry Babin  United States
I've never tried but I think it can be powered up without the pots.
Old 1st December 2012, 09:56 AM   #62
seankane is offline seankane  United States
seankane's Avatar
Well I replaced both pots and transistors anyway just because I have them.
No change still pulsing......I dont get it why would shorting the e-c of the bias transistor allow the amp to not pulse and produce clean audio?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 1st December 2012, 10:18 AM   #63
seankane's Avatar
I removed the jumper from the bias transistor and followed its traces through the board and one of them went to Q309 and from there to Q310.
I removed Q309 and Q310 from the circuit and the amp idles fine with no pulsing but does not produce clean audio.
I will try and put new Q309 and Q310 in the board to see if it helps.
Old 1st December 2012, 10:24 AM   #64
seankane's Avatar
No difference re-installed a new Q309 and Q310 and the pulsing is back and 3 series outputs are getting hot still.....I am truly at a loss here.
Old 1st December 2012, 02:34 PM   #65
What is the DC voltage across C203 and C205?
Old 1st December 2012, 05:26 PM   #66
seankane's Avatar
Should I re-install Q206 and Q207 first?
Could you mean C205 and C303 as I dont find any C203 on the board???
Old 1st December 2012, 05:40 PM   #67
Make that C303 and C305.
Old 1st December 2012, 06:18 PM   #68
seankane's Avatar
Shall I re-install the jumper first so its not pulsing or do you want it pulsing while testing?
Old 1st December 2012, 07:54 PM   #69
Yes.
Old 1st December 2012, 08:14 PM   #70
seankane's Avatar
C303: -19.49 vdc
C305: -20.61 vdc
Rockford Fosgate Punch 800.2Hide this!Advertise here!
rockford fosgate punch 800 a2 ernie cosillos Car Audio 3 12th June 2011 01:41 AM
Fosgate Punch 800 a4, diagram needed camoandbee Tubes / Valves 0 13th April 2011 06:33 PM
Rockford Fosgate 800.2 Brain Fried Car Audio 2 16th April 2010 05:14 PM
rockford fosgate punch z stevena2006 Car Audio 2 23rd December 2009 04:20 PM
Rockford Fosgate Power 800.4 lostamps Car Audio 6 2nd January 2008 12:21 PM
