Rockford Fosgate Punch 800.2
Old 30th November 2012, 11:19 AM   #31
Perry Babin is offline Perry Babin  United States
Is there any DC on the output of that channel?
If not, short the bias transistor from collector to emitter with a jumper wire and remove the jumper from C5. Does the amp power up and idle?
Old 30th November 2012, 06:40 PM   #32
seankane is offline seankane  United States
seankane's Avatar
All the outputs are in the amp now.
The channel I originally posted the picture of with all the burned source resistors has no DC.
The channel I replaced the 6 IRF640's in has 0.220 vdc.
Shall I do the jumper on Q308 still?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 30th November 2012, 06:47 PM   #33
seankane's Avatar
There is a small amount of DC on that channel about 0.220 vdc, but I soldered a jumper from collector to emitter on Q308 and removed the jumper from C5 and the amp pulses.
0 amps to 40 amps over and over.
Old 30th November 2012, 07:53 PM   #34
Remove all jumpers and lift Qx06 and Qx07 (I'm not sure which channel this is). Does the amp still pulse?
Do you have any DC across the speaker terminals with those transistors out of the circuit?
Old 1st December 2012, 03:15 AM   #35
seankane's Avatar
I will lift Qx06 and Qx07 in both channels. Even when the IRF640's were removed as soon as I put the outputs back in the defective channel you saw the picture of it started pulsing.
Seems to only pulse when the IRF640's of either channel are installed.
Old 1st December 2012, 03:22 AM   #36
seankane's Avatar
I removed Q306 and Q307 first then powered the amp still pulsing.
Left Q306 and Q307 out of the circuit and removed Q206 and Q207 and the amp stopped pulsing and idles fine with no DC on either terminal.
Thoughts?
Old 1st December 2012, 04:04 AM   #37
Which channel has the heating outputs (200 series or 300 series)?
Old 1st December 2012, 04:06 AM   #38
seankane's Avatar
3 series
Old 1st December 2012, 04:38 AM   #39
Does the 300 series channel now produce clean audio?
Old 1st December 2012, 04:45 AM   #40
seankane's Avatar
Scope settings are 2ms 2v/d and no neither channel does.
When the volume is first increased it looks ok go a little higher it looks like a shark fin, starts curving back to a point.
Rockford Fosgate Punch 800.2Hide this!Advertise here!
rockford fosgate punch 800 a2 ernie cosillos Car Audio 3 12th June 2011 01:41 AM
Fosgate Punch 800 a4, diagram needed camoandbee Tubes / Valves 0 13th April 2011 06:33 PM
Rockford Fosgate 800.2 Brain Fried Car Audio 2 16th April 2010 05:14 PM
rockford fosgate punch z stevena2006 Car Audio 2 23rd December 2009 04:20 PM
Rockford Fosgate Power 800.4 lostamps Car Audio 6 2nd January 2008 12:21 PM
