Rockford Fosgate Punch 800.2
Old 3rd December 2012, 05:42 AM   #91
Perry Babin is offline Perry Babin  United States
Leave it directly connected to the supply but connect it to a speaker or dummy load and post a photo of the defective channel driven to clipping.
Old 3rd December 2012, 08:43 AM   #92
seankane is offline seankane  United States
seankane's Avatar
I cant it maxes out my power supply before the signal clips.
When I get to about 1/4 volume I am drawing 60 amps thats all my supply has, it kicks my supply into protect.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 4th December 2012, 05:29 AM   #93
seankane's Avatar
Did you get a chance to read post #92?
Maybe I am connecting the load to the amp improperly?
Old 4th December 2012, 05:34 AM   #94
You connect it to the speaker terminals like you would a speaker. You only need to load the distorted channel. It doesn't need to be a 2 ohm load. It can be a 4 or even an 8 ohm load.
Old 4th December 2012, 06:38 AM   #95
seankane's Avatar
Thats how I had it hooked up.
I have 4..... 8 ohm resistors wired in parallel, 4 leads to one end and 4 leads to the other end. I hooked a terminal of the amp to each end.
I only had it hooked to the bad channel. Maybe a 2 ohm load makes the amp draw to much current?
I guess I could just use 1 and do an 8 ohm load that probably wouldnt draw much current?
Old 4th December 2012, 06:50 AM   #96
seankane's Avatar
Amp connected straight to supply, all parts in circuit, all 3 jumpers installed, defective channel, 8 ohm load, scope set at 2ms/20vd.
File Type: jpg 800.2 output with a 8 ohm load 001.jpg (824.8 KB, 39 views)
Old 4th December 2012, 05:04 PM   #97
Lift D202 again to see if there is any change with the load.
Old 4th December 2012, 07:11 PM   #98
seankane's Avatar
Im sorry Perry I should have been more specific, all parts are in the circuit except D202.
The load signal you are seeing is with D202 removed.
Old 4th December 2012, 09:03 PM   #99
Try this with both a higher and lower frequency signal. Does the distortion always happen precisely the the bottom of the waveform?
Is there possibly a small ceramic capacitor near the components that were replaced that was damaged?
Old 5th December 2012, 03:57 AM   #100
seankane's Avatar
Amp connected directly to supply, all parts except D202 in circuit, all 3 jumpers installed, 8 ohm load, scope setting 2ms/20vd.
1st pic: high frequency
2nd pic: low frequency
It seems to be more sensitive to the higher frequency.
The lower frequency still kinda looks funny at full volume.
Rockford Fosgate Punch 800.2Hide this!Advertise here!
rockford fosgate punch 800 a2 ernie cosillos Car Audio 3 12th June 2011 01:41 AM
Fosgate Punch 800 a4, diagram needed camoandbee Tubes / Valves 0 13th April 2011 06:33 PM
Rockford Fosgate 800.2 Brain Fried Car Audio 2 16th April 2010 05:14 PM
rockford fosgate punch z stevena2006 Car Audio 2 23rd December 2009 04:20 PM
Rockford Fosgate Power 800.4 lostamps Car Audio 6 2nd January 2008 12:21 PM
Copyright ©1999-2017 diyAudio
