diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   Hifonics Brutus BRZ1700D.1 (http://www.diyaudio.com/forums/car-audio/224318-hifonics-brutus-brz1700d-1-a.html)
seankane 26th November 2012 01:29 AM
Hello amp powers up but its in protect and has no output.
Shorted outputs or faulty protection?
Thinking about buying this amp just want a heads up on what I may be getting myself into??
seankane 26th November 2012 01:31 AM
1 Attachment(s)
A pic of the board, looks to be the same as the brutus BX2005D Perry helped me with.
Perry Babin 26th November 2012 02:18 AM
The two 1D transistors on the driver board are the most likely suspects. Let me know if you need a photo.
blazer40 26th November 2012 02:51 AM
About 50% of these that I get in are exactly what Perry says. You can replace em without pulling the driverboard (it's tricky, but do-able). Even when they aren't bad, I still put fresh ones in.
Perry Babin 26th November 2012 02:52 AM
It's easy to replace them in the amp if you stand the amp on end.
seankane 26th November 2012 05:48 AM
Thats how I did the BX2005D we worked on was stood the amp on end so I didnt have to remove the board again it was easy that way.
seankane 11th December 2012 06:58 PM
Originally Posted by Perry Babin (http://www.diyaudio.com/forums/showthread.php?p=3256785#post3256785)
Perry, wondering if you could post that photo of which two 1d transistors they are. The last hifonics I worked on I replaced them all and I dont want to replace unecessary parts.
Is it a good practice to replace them all of just the two you mentioned?
I bought the amp, "should" be an easy fix!!
timwebb 11th December 2012 10:44 PM
most times u have to replace both.
seankane 12th December 2012 03:35 AM
Theres 5 1d's on the audio board I was wondering which two are the common ones to go out?
The last amp I just replaced all of them including the 2d's and one of the op-amps.
I guess I will just replace them all.
timwebb 12th December 2012 03:44 AM
they will be in the center of the board.
Copyright 1999-2017 diyAudio
