Help: Rockford fosgate 551s power amp or Kicker zx750.1 amp?? - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 25th November 2012, 10:29 PM   #1
Default Help: Rockford fosgate 551s power amp or Kicker zx750.1 amp??
I have a JL Audio 10w7 that i'm getting ready to install. I have a choice to run either of these two amps. My question is, which amp would be better to run for one 10 w7? I want to get the most out of the sub with either of these amplifiers. What do you guys think?
Old 25th November 2012, 10:48 PM   #2
The 750.1 will run cooler and likely produce more power.
Old 25th November 2012, 10:57 PM   #3
The 750.1 puts out 750x1 rms @ 2 ohms and the 551s 550x1 rms @ 4 ohms. How would these numbers be affected by the 3 ohm subwoofer?
Old 25th November 2012, 11:00 PM   #4
Single or dual 3 ohm?
Old 25th November 2012, 11:01 PM   #5
I am not positive whether it's a single or dual voice coil. Is there a definitive way to tell.by looking at the sub?
Old 25th November 2012, 11:13 PM   #6
It appears (from what I could see on the JL site) that they are either 3 ohm SVC or dual 1.5 ohm voice coils. If it says 3 ohms on the terminals, it's a 3 ohm woofer.
The Rockford could not safely drive it bridged.
Old 25th November 2012, 11:16 PM   #7
Because of the 4 ohm output I assume?
Old 25th November 2012, 11:40 PM   #8
Because the lowest rated load is 4 ohms bridged.
Old 25th November 2012, 11:43 PM   #9
Well Kicker it is then I suppose. Is the kicker amp bridgeable and if not how should I wire it? Btw, thank you for the help. It is appreciated.
Old 25th November 2012, 11:45 PM   #10
There is only one way to wire that sub to that amp.
What is a rockford fosgate amp t40001bd amp worth? SpinMonster Swap Meet 1 23rd July 2012 05:26 AM
Need help with no sound from kicker zx750.1 amp kylelemay1 Class D 0 7th May 2011 05:46 PM
Rockford fosgate amp mike49504 Car Audio 16 25th April 2010 10:30 PM
Help for a Kicker ZX750.1 that goes into protection in 15 mins & does not get warm. BIG4REST Car Audio 0 14th August 2009 10:40 PM
Copyright 1999-2017 diyAudio
