If the protection Diodes in a channel are bad would that cause that channel to have no output ??
If so Does anyone know what 2 diodes i need to pull They are the 400 series parts..
If i use the Scope Its saying i have audio all the way up to the Right front positive speaker terminal But i have no output at all out of that channel..
I clean the crossover switch still nothing
Any ideas?
Any ideas?
D401 and D402 are for the protection circuit. It's unlikely that both halves of the protection circuit have failed but anything is possible.
Confirm that you have essentially the same voltage across R417/418 as as you do on the same resistors in the other channels.
Sounds to me you have the same problem as the punch 360a2 Perry helped me with awhile back, I am not sure if the 4 channel amps are the same as the 2 channel amps and I dont have that schematic in front of me but......if they are the same check RX53-RX59 to see if any of those resistors are out of tolerance.
- General Interest
- Car Audio
- Rockford Fosgate 750 x
