JL Audio 1000/1
JL Audio 1000/1
Old 23rd November 2012, 06:11 AM   #1
S Merlington is offline S Merlington  United States
Default JL Audio 1000/1
Does anyone know the value of R842 ??
It sits beside the small yellow transformer
Old 23rd November 2012, 07:22 AM   #2
Perry Babin is offline Perry Babin  United States
The large resistor next to the large 33 ohm resistor is 0.1 ohms.
Old 23rd November 2012, 07:24 AM   #3
Is the SMD resistor that sits next to C837 and C839 also a 0.1 ohm ?
Old 23rd November 2012, 07:28 AM   #4
This one?
47 ohms.
Old 23rd November 2012, 07:49 AM   #5
Replaced both of the resistors As soon as i power it up both resistors burn within 2 secs
Old 24th November 2012, 05:38 PM   #6
Would you happen to know what should check next since both thoose resistors i jus put in burn up within 2 secs
Old 24th November 2012, 05:44 PM   #7
The only thing connected to both of those resistors is the transistor standing on the board right next to the resistors.
Old 24th November 2012, 05:48 PM   #8
Yeah thats it its shorted from Legs 1-3
Is there anything i can use for a sub so i can est somemore ??
Orginal is a FQP30N60L
Old 24th November 2012, 07:26 PM   #9
30N06L, not 30N60L.
This is a 'logic level' FET. The drive circuit doesn't have enough voltage to properly drive a standard FET. You may be able to use something like a 3205 for testing to see if there are other problems but you'll need to get the proper transistor for long term use.
Old 28th November 2012, 06:08 AM   #10
Ok i orderd the Correct transistor.. (FQP30N06L)
The 47 ohm resistor connected to Leg 1 of that transistor both of the pads burnt off the board...
Instead of an SMD resistor going back in that location I was gonna use a leaded resistor to i can solder right to leg 1 and the other side i can drill a small hole thru the board and solder it from the under side of the board..
Would a 1/4 watt 47 ohm resistor work or should i use a 1/2 watt ?
Also the 0.1 ohm resistor is a 2 watt ??
3rd question is With the FQP30N06L , 0.1 ohm and the 47 ohm resistor all being bad would that cause the low ohms light ?
JL Audio 1000/1Hide this!Advertise here!
JL Audio 1000/1 S Merlington Car Audio 9 18th September 2012 08:15 PM
JL AUDIO 1000/1 mike49504 Car Audio 55 11th September 2012 05:28 PM
JL Audio 1000/1 Dr Zeus Car Audio 33 8th February 2012 02:18 AM
JL AUDIO 1000/1 ALPINE AJ Car Audio 3 22nd August 2011 04:45 PM
Jl audio 1000/1 mike49504 Car Audio 1 22nd May 2010 08:21 PM
Copyright ©1999-2017 diyAudio
