Kenwood KAC-1023
Kenwood KAC-1023
Old 19th November 2012, 05:20 PM   #1
SlappinM30 is offline SlappinM30  United States
SlappinM30's Avatar
Default Kenwood KAC-1023
I have a Kenwood KAC-1023 that I have had for a few years that I would like to fix. About 2 years back I ran this amp at 2 Ohms bridged (knowing it was a bad idea), it did this for nearly a year. A climate change ended it's life. It normally ran warm, but when the outside temp went up it couldn't handle it. The fans would almost always run and the heat sink would run hot. Well like I say one day it could take it no more and it stopped working. The board does show some sings of heat and two of the lager caps seems to have leaked, all of the fets look fine though. I have included some pics and if any of you have possible parts and spec info that would be great.
Krystal Klear Audio Works
http://krystalklearaudioworks.vpweb.com
Old 19th November 2012, 05:36 PM   #2
Perry Babin is offline Perry Babin  United States
Screw those transistors back down to the riser plate before you apply power.
What does it do when you try to power it up?
Old 19th November 2012, 05:39 PM   #3
SlappinM30's Avatar
The amp is all back together at this point.
Well the amp lights up for a split second the it over loads my power supply (an old comp. power supply), no fuses blow.
Old 19th November 2012, 05:42 PM   #4
Did you check for shorted output transistors?
As a side note, the caps may not have leaked. The substance around them appears to be a fixative.
Old 19th November 2012, 06:57 PM   #5
SlappinM30's Avatar
Those are the smaller one's right (the 1190's)?
Old 19th November 2012, 07:50 PM   #6
The outputs are the larger components that have exposed metal tabs at the top.
Old 19th November 2012, 07:55 PM   #7
SlappinM30's Avatar
When using the Neg terminals I don't see any shorts there.
Old 19th November 2012, 07:55 PM   #8
The negative terminals?
Old 19th November 2012, 07:58 PM   #9
SlappinM30's Avatar
The power and ground terminals, I located the black lead on the Neg. and used the red to go through all the legs.
Old 19th November 2012, 07:58 PM   #10
SlappinM30's Avatar
Can I power up the power section while it is out of the main body?
Kenwood KAC-1023Hide this!Advertise here!
I have a Kenwood Kac-1023 amp and need HELP... BKLYNNY1 Car Audio 10 29th January 2011 02:02 AM
Kenwood KAC-1023 crossover/gain board, same as in other *23-series? gisewhcs Car Audio 9 25th January 2011 02:04 AM
Kenwood KAC-1023 sst12 Car Audio 0 19th September 2010 01:19 PM
Another KAC-1023 question sdoom Car Audio 1 19th August 2010 10:31 PM
Service manual for Kenwood KAC-1023 sdoom Car Audio 4 28th September 2009 12:27 AM
