MMATS  D2000.2
MMATS  D2000.2
Old 19th November 2012, 11:25 AM   #21
S Merlington is offline S Merlington  United States
Well that would explain the power supply issue
Old 23rd November 2012, 07:09 AM   #22
I put a Mic4424 in the socket and the power light lights up now but the amp draws excessive current and fets heat up within 2 secs
The outputs are out of the amp right now also the hip 4080 is out
Any ideas?
Old 23rd November 2012, 07:25 AM   #23
Perry Babin is offline Perry Babin  United States
Post a photo of the board.
Old 26th November 2012, 02:35 PM   #24
I gotta run and get a new camera cord later so i can post a pic..
Heres what i have on the Sg3525 now do theese voltages apper corret or is there an issue
Pin 1:2.13
Pin 2:5.14
Pin 3:0.00
Pin 4:1.08
Pin 5:1.80
Pin 6:3.80
Pin 7:1.82
Pin 8:0.47
Pin 9:6.00
Pin 10:0.00
Pin 11:0.00
Pin 12:0.00
Pin 13:13.13
Pin 14:0.00
Pin 15:0.00
Pin 16:5.14
Heres what i get on the MIC4424
Pin 1:0.00
Pin 2:0.00
Pin 3:0.00
Pin 4:0.00
Pin 5:0.00
Pin 6:0.00
Pin 7:13.12
Pin 8:0.00
Im not sure if its the right driver ic or not..
Heres what i get
Pin 11 of the Sg3525 would connect to PIn 4 of the driver IC
Pin 14 would connect to PIN 2
Pin 3 of the Driver IC would be connected to ground
Pin 8 of the Driver IC would connect to the Gate Leg of the Power supply fets
Pin 3 of the Driver IC would connect to the source leg of the power supply fets
The drain Leg of the Fet would connect to the emitter of an 2N4403
Does this make sense and does it apper that thats the correct driver IC and do the voltages apper to be right or is there something wrong ?
Old 26th November 2012, 02:41 PM   #25
I wouldn't expect the FETs to be heating up. There is no drive voltage.
Old 26th November 2012, 02:49 PM   #26
The fets dont heat up at all now amp doesnt power up
Old 26th November 2012, 03:27 PM   #27
I think that there is at least one mistake with the voltages on the 3525. Recheck them. Pin 15 would have to be at at least 8v to have 5v on pin 16.
Old 26th November 2012, 08:20 PM   #28
SG3525
Pin 1:0.00
Pin 2:5.14
Pin 3:0.00
Pin 4:1.08
Pin 5:1.79
Pin 6:3.79
Pin 7:1.71
Pin 8:0.48
Pin 9:6.00
Pin 10:0.00
Pin 11:0.00
Pin 12:0.00
Pin 13:13.13
Pin 14:0.00
Pin 15:13.13
Pin 16:5.14
Old 26th November 2012, 08:53 PM   #29
Pin 8 isn't high enough. It should be near 5v. This is the soft-start terminal. An internal constant-current source charges an external capacitor. The most likely problems are a leaky cap, a defective CCS inside the IC or possibly an external component holding it down.
Pin 4 also is a bit higher than normal but that may be because the output is shut down.
MMATS  D2000.2Hide this!Advertise here!
FS MMATS MMATS MMATS zade08 Swap Meet 1 27th April 2013 02:36 AM
MMATs 3000.1 m4ick Car Audio 23 22nd March 2012 10:49 AM
MMATS D200 NickParr666 Car Audio 1 2nd December 2011 10:43 PM
MMats Pro Audio D2000.2 mike49504 Car Audio 0 6th January 2011 05:03 PM
TEAC PL-D2000 DVD player 8969ko Digital Source 1 28th March 2006 02:38 AM
