Earthquake 200DHC
Earthquake 200DHC
Old 24th December 2012, 05:18 PM   #21
S Merlington is offline S Merlington  United States
Scope set to 5 ms 10 volts/div
200 hz sine wave
First pic is on the positive terminal
2nd pic is the negative terminal
Old 24th December 2012, 05:57 PM   #22
Perry Babin is offline Perry Babin  United States
Do you have a triangle waveform on pin 6 of the 4080?
Old 24th December 2012, 06:05 PM   #23
Yes
Old 24th December 2012, 09:35 PM   #24
Do you have audio on pin 7?
Does this amp have pull-down resistors on the output transistors?
Old 25th December 2012, 01:36 AM   #25
It has audio on Pin 7 but its clipped the bottom of the sine wave is flat..
Yes the outputs have pulldown resistors..
Old 25th December 2012, 12:18 PM   #26
If you're absolutely sure that it has pull-down resistors on the outputs, remove the 4080 and see if it has a clean signal on pin 7.
Old 25th December 2012, 09:39 PM   #27
Pulled the HIP4080 and tested for audio on Pin 7 I get a square wave on Pin 7 so the audio is clipped
Old 25th December 2012, 09:45 PM   #28
Do you get clean audio if you short pins 8 and 9 of IC2?
Old 25th December 2012, 10:04 PM   #29
Yes
Old 25th December 2012, 10:14 PM   #30
That would seem to indicate that the components feeding the 4080 are OK. Remove the jumper.
Do you get clean rail-rail oscillation on the output transistors?
Earthquake 200DHCHide this!Advertise here!
Earthquake PH5000D S Merlington Car Audio 2 31st October 2012 01:45 AM
earthquake 200dhc DREW028 Car Audio 13 2nd June 2012 07:06 AM
earthquake 200dhc power supply repair ivkata Car Audio 1 18th April 2012 08:54 AM
Earthquake 200dhc with hum in output spooney Car Audio 23 27th November 2010 08:15 PM
-:- Earthquake -:- audioPT Subwoofers 3 30th October 2004 01:02 PM
