Earthquake 200DHC
Earthquake 200DHC
Old 27th November 2012, 05:25 AM   #11
S Merlington is offline S Merlington  United States
Power supply is up and running perfectly..
I stuck the output in the amp and they burnt up within a few seconds..
The Orginals were STP50NE10's IS it ok to replace them with IRF3710Z's ?
Also Not sure if the HIP4080 is defective or not but the diode solderd from pins 11 to 12 is shorted..
Also does this amp have negative rail voltage I only get positive rail voltage..
Old 27th November 2012, 02:15 PM   #12
Perry Babin is offline Perry Babin  United States
Virtually all 4080 based amps use a single rail for the output stage.
I'd suggest replacing the 4080 any time that any output has failed.
Do you know why the outputs failed?
Did you check them before powering the amp up?
Did you ever power it up with the 4080 out of the circuit?
Old 27th November 2012, 02:31 PM   #13
Not sure why the outputs failed..
I powerd the amp up with the hip4080 removed only after the outputs failed
Old 27th November 2012, 02:43 PM   #14
The 3710Zs are rated for less current than the original FETs but I know of no other FET that's likely to work.
For future reference, some 4080 amps lack pulldown resistors for the output transistors. Powering those amps up with the 4080 out of the circuit will cause the outputs to fail.
Old 28th November 2012, 07:45 AM   #15
Ok i orderd new outputs (IRF3710Z's) and a new HIP4080
The 2 diodes (1N5234) 1 of them solders between legs 11 and 12 the other diode solders between Pins 19 and 20..
Are theese diodes just there to protect the IC ?
Old 28th November 2012, 04:12 PM   #16
I think the diodes are there to protect the FETs (maybe the IC) if the speaker wires are shorted to ground.
Old 9th December 2012, 11:20 PM   #17
Installed the 3710Z's for the outputs put in a new HIP4080 And replaced the diode on the HIP4080..
Amp powers up and idles fine Produces audio but when i turn the crossover settings up the outputs is distorted..
Also the HIP4080 is getting hot within 1 min is this normal or not ?
I also have 0.38 volts measured directly across the output terminals If i try to mess with the DC offset pot it will increase to 30 volts but it wont go any lower so 0.38 volts is as low as i can get it to go..
Old 10th December 2012, 02:50 AM   #18
Post a photo of the distorted waveform.
The 4080s get warm but shouldn't get too hot to hold your finger on in a minute.
Old 23rd December 2012, 06:26 PM   #19
Scope is set to .5ms 1 volts/div
This is with a 200hz sine wave
First pic is taken with the probe touching the rca jack
2nd pic is on the positive output terminal
Old 24th December 2012, 05:27 PM   #20
Set the scope to 10v/div and post photos of the waveforms on both the positive and negative speaker terminals.
Earthquake 200DHCHide this!Advertise here!
Earthquake PH5000D S Merlington Car Audio 2 31st October 2012 02:45 AM
earthquake 200dhc DREW028 Car Audio 13 2nd June 2012 08:06 AM
earthquake 200dhc power supply repair ivkata Car Audio 1 18th April 2012 09:54 AM
Earthquake 200dhc with hum in output spooney Car Audio 23 27th November 2010 09:15 PM
-:- Earthquake -:- audioPT Subwoofers 3 30th October 2004 02:02 PM
Copyright ©1999-2017 diyAudio
