Way to change Ohm load capability - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 15th November 2012, 11:21 PM   #11
SlappinM30's Avatar
Running them at 4 ohms would most likely be a little cleaner but running the amp at 1 ohm they seem to be faster, or is that all in my mind?
Krystal Klear Audio Works
http://krystalklearaudioworks.vpweb.com
Old 16th November 2012, 06:29 AM   #12
What do you mean by 'faster'?
Old 16th November 2012, 06:46 AM   #13
SlappinM30's Avatar
It seems that with the lack of resistance the speakers react faster. Like I say is this all in my head?
Old 16th November 2012, 07:01 AM   #14
The speakers react as soon as the signal is driven into them.
Old 16th November 2012, 01:56 PM   #15
to answer your original question, yes. it is done, but the work is not cheap. many times you can upgrade components to handle more current, but you need to be able to do this to the whole system. next, figure out how much power it can safely run, and lower the voltage accordingly to not exceed that. this is done via torroid re-work and often needed to have the ps controller circuit modified to react to that voltage. someone who can, and is willing to put in the work needs to decide if that amp is even worth the effort, or should be kept at higher ohm loads.
How to change ohm value of speaker? henkel Multi-Way 24 30th June 2013 12:44 AM
Dummy load to change speaker impedance? nonsuchpro Multi-Way 7 8th August 2012 12:56 AM
PA150 (3x LM3886) 2 ohm capability ? nickthevoice Chip Amps 12 16th September 2010 08:12 PM
What's the closest I can get to a 4 ohm load using 3 single coil, 6 ohm drivers? The Paulinator Multi-Way 9 11th May 2004 08:04 PM
Copyright 1999-2017 diyAudio
