O/S Mobile Authority 116ZX amplifier
Old 19th December 2013, 11:37 PM   #31
Madjimms is offline Madjimms  United States
Does this mean I damaged more components? or should I just replace the resistors and transistors and I'll be good?
Why does the datasheet say 2SB829/2SD1065?
Old 19th December 2013, 11:50 PM   #32
Perry Babin is offline Perry Babin  United States
I don't know if you've done any other damage.
The datasheet covers two complementary parts. Complementary parts are typically parts with similar specifications but with opposite polarity. Complementary parts are often used in the output stage of amplifiers.
I'd buy the original parts from pacparts.com. There are a lot of counterfeit parts on eBay. Pacparts should be safe but when buying discontinued parts, there is a risk of getting counterfeit parts.
Old 19th December 2013, 11:56 PM   #33
Thank you for your help Perry and others. I feel like a complete noob but at the same time I have learned quite a bit. I'll be ordering the CORRECT replacements from Ebay after Xmas, but I still can't figure out the resistor colors, What is your educated guess judging from the pictures (I'm partially color blind so it doesn't help)
Old 20th December 2013, 12:24 AM   #34
If you order from eBay, EXPECT to get parts that won't work.
I don't know how the resistor is being used.
Old 20th December 2013, 01:41 AM   #35
evianamp2011 is offline evianamp2011  United States
evianamp2011's Avatar
UTSOURCE has them (they have their own website or have an ebay account). I trust them because I have had successful repairs with their "hard to find" components.
The only downside is you have to wait two weeks for it to arrive, but don't worry S&H is ONLY 4.00 WTF!!!! YEP.
Tek TDS1002B, Rigol DS1052E, Keithley 2015THD, Fluke 87-V 83-V & 111, DC Clamp meter, APS 90a 13.6v PS, Adjustable 0-30v/0-5a PS.
Old 20th December 2013, 01:59 AM   #36
Search turned up 0 for 2SD1065. Also with ebay I expect to take a chance, because nowhere else has the part anywhere near the price.
EDIT Found several equivalents but not sure what one would be the best http://alltransistors.com/crsearch.p...=70&caps=TO247
The one with 150W TDP and 450v UCB looks interesting, but I don't think I could alter to make it work.
Old 20th December 2013, 03:02 AM   #37
I can find similar rated NPN's on DigiKey but some of the values are different. What category should I search under, FET, BJT,special purpose?
Old 20th December 2013, 03:04 AM   #38
It's difficult to find equivalent transistors. These are designed for switching at high speeds. Transistors not designed for this will run hot, even if they seem to have better specs.
Old 20th December 2013, 03:16 AM   #39
Maybe my Coustic Power Logic AMP-210X would be less troublesome.
O/S Mobile Authority 116ZX amplifierHide this!Advertise here!
Moblie Authority 38xi ian33 Car Audio 0 12th November 2011 09:08 PM
Channel volumes differ on Mobile Authority 120ZX amp KyferEz Car Audio 10 5th February 2008 11:56 PM
Testing & Measurement Methods for Mobile Audio Amplifier Hi Speed Car Audio 0 20th May 2004 05:19 AM
mobile monitors zaboo3 Everything Else 1 17th July 2003 12:05 PM
