MOSFET clamp for RF punch 225.2, can I make my own?
Old 14th November 2012, 08:25 PM   #1
chipper is offline chipper  United States
Send a message via MSN to chipper Send a message via Yahoo to chipper
Default MOSFET clamp for RF punch 225.2, can I make my own?
Hello everyone, I got in a rockford fosgate punch 225.2. I received as a mess I got the power supply up and running but I guess someone before me tried removing the old fets off the mehsa and pulled the whole solder pad out so that's now useless, I have a parts 40ix and it has the clamp bars I took one out put it by the power supply fets in the 225.2 the hole to put the screws match perfect enough to clamp down the two fets, anywy I was thinking of cutting piece of the mehsa that's useles putting mica insulators for the fets and cutting the clamp bars to hold the fets, seems like it work. What do you guys think??
I would post pics but I'm on mobile.
And one channel is shorted and the other plays fine but has a little distortion in it.
Feel the PUNCH
Old 14th November 2012, 08:37 PM   #2
This is what I did
Feel the PUNCH
Old 14th November 2012, 08:50 PM   #3
Wrong pic, here's my final work
Feel the PUNCH
Old 15th November 2012, 01:44 AM   #4
seankane is offline seankane  United States
seankane's Avatar
The original size of the material was 3/16" x 1/2" you can buy the aluminum flat bar and cut your own and easily layout the holes by tracing them from the MESHA board.
What you have will work and if your going to keep it thats fine, if your going to sell it especially on ebay I would remove both MESHA boards and put down tape and use a full length clamp for both sides.
I probably have both MESHA boards for that amp, I have a ton of them laying around. I probably even have the correct length OEM clamps from another amp as well.
The 225.2 probably uses 6/32" x 3/8" screws for the MESHA some of them used 8/32" x 3/8" and are different than the DSM amp style screw for the aluminum clamp.
The DSM amps I believe use an 8/32 x 3/4" with a shouldered 6 point head which is 1/4" in size.
You would have to go to the hardware store and get the proper length screws for using the aluminum bar clamp.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 15th November 2012, 02:14 AM   #5
I plan on keeping this amp, what would you charge me for the mehsa boards?
Feel the PUNCH
Old 20th November 2012, 05:42 PM   #6
You never got back to me for mehsa boards for a punch 225.2 amp. Lmk when you have time bro
Feel the PUNCH
Old 21st November 2012, 08:36 AM   #7
seankane's Avatar
You have a new PM.
MOSFET clamp for RF punch 225.2, can I make my own?Hide this!Advertise here!
RF Punch 200a4 nearly the same as 400a4? gisewhcs Car Audio 6 12th September 2011 09:24 PM
RF Punch 200a4 Noise faul Car Audio 4 22nd October 2010 05:24 AM
Blown power supply transistors in punch 225.2 chipper Car Audio 14 1st April 2010 10:40 PM
RF Punch 150 chipper Car Audio 8 24th September 2009 12:08 AM
RF Punch 75.2, help plz JSmooth420 Car Audio 5 17th September 2006 10:20 AM
Copyright ©1999-2017 diyAudio
