Go Back   Home > Forums > General Interest > Car Audio
Old 17th November 2012, 08:44 AM   #21
rrae is offline rrae  Norway
Yes Perry, i can confirm. I got -63v and +33v. measurement done by - black probe at negative terminal, red on each rectifier center leg.
DMM
Old 17th November 2012, 01:57 PM   #22
Use the negative speaker terminal for the reference point (black probe).
Old 17th November 2012, 04:20 PM   #23
Then i got +65v and -66v
DMM
Old 17th November 2012, 05:05 PM   #24
Check the legs on the rectifiers to see if any are broken.
Old 20th November 2012, 04:13 PM   #25
They are good, i replaced them, still the same.
DMM
Old 20th November 2012, 05:01 PM   #26
Ok, when i operate "high/low" (!) level switch, my rails at rectifiers are changing. When switch is in position "hi" - my readings at rectifiers are -62v and +33V on center legs. When switch is in "low" position, i get -32 and +33. Amp ground terminal as reference.
When using negative speaker terminal as reference, i get good -62v and +62v on both switch positions.
DMM
Old 20th November 2012, 07:34 PM   #27
Is the high/low audio signal input switch?
That shouldn't make a difference since it only appears to change where the amp gets it's turn-on signal.
Use the negative speaker terminal as the reference when measuring the voltages on the secondary side of the power supply (rail, regulated...).
At this point, does the amplifier produce audio?
dls cad 11 fra Car Audio 8 31st October 2012 08:40 PM
WTB: Jensen JT-11-BMCF or JT-11-DMCF or Lundahl LL1690 Groundloops Swap Meet 1 1st February 2012 08:37 AM
CD80 clock frequency 11.2896 to 11.0592? Sam Spade Digital Source 5 24th October 2010 03:44 PM
DLS audio for sale vickyz Vendor's Bazaar 1 27th July 2007 12:22 AM
free 11 by 11 inch heatzinc good for class a karma Swap Meet 9 14th January 2007 02:30 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
