New to amp repair and the forum
Old 14th November 2012, 12:18 AM   #11
Perry Babin is offline Perry Babin  United States
What have you done to determine that they need to be replaced? Are you sure that they're defective?
Old 14th November 2012, 12:19 AM   #12
That sounds like you have shorted output transistors.
Old 14th November 2012, 02:18 AM   #13
1moreamp is offline 1moreamp  United States
Perry is correct you most likely have a shorted output or two. I have rarely seen a power supply fail that was not caused by shorted outputs or other issues elsewhere inside the amp.
Use a three amp blade fuse inline with the supply this amp should power up at about 1 amp and no more. I have seen a few of these back in the day. I think they had IRFZ-34 in the supply to begin with. But Perry's suggestion of Z-44's should work just fine....
New to amp repair and the forumHide this!Advertise here!
Household Appliances repair forum Tarzan Everything Else 7 22nd August 2012 07:54 PM
Forum 'Category' appears at the top of the forum list dfidler Forum Problems 0 14th August 2010 07:55 PM
T-amp threads should be transferred to chip amp forum Workhorse Class D 30 6th May 2010 08:42 PM
Forum donation in honour of a forum member tinitus Everything Else 0 25th October 2009 01:45 PM
French people on the forum ? Des Franšais sur le forum ? frankie Introductions 19 30th December 2002 08:40 PM
Copyright ©1999-2017 diyAudio
