#21 |
How do i test to see if the opto-coupler is being driver to bias or if its not being driven on??
#22 |
Measure the DC voltage across pins 1 and 2 from the time that remote is applied and for about another 10 seconds. It should go from about 0v to about 1.2v DC.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#23 |
There are 2 Opto -couplers in this amp 1 of them goes from 0 to 1.01 volts
The other 1 stays at -0.46 volts across pins 1 and 2 |
#24 |
For the one that goes from 0 to 1v, measure the voltage on the other side of it. Does it go from about 70v to about 0v?
#25 |
It goes from 60.5 volts to 0 volts
#26 |
You should see oscillation on the output transistors when that switches to 0v. Do you see oscillation on the outputs?
Do you see any DC offset after it switches?
#27 |
The DC offset goes from 2.22 volts when powerd up to 0 volts when it switches..
Yes i see oscillation on the outputs |
#28 |
Are you getting a preamp level signal to the amplifier section of the amp?
Did you compare it to the sony XM-D400P5?
#29 |
I dont have the service manual for the sony..
The audio is not reaching the Amplifier section of this amp |
#30 |
email me
babin_perry@yahoo.com
| Earthquake PH2000 | mike49504 | Car Audio | 21 | 4th May 2012 04:50 AM |
| Earthquake PH2000 | mike49504 | Car Audio | 10 | 11th February 2012 08:38 AM |
| Earthquake subwoofers ?? | Moondog55 | Subwoofers | 0 | 11th August 2009 06:19 AM |
| Earthquake UHC2020 | Puggie | Car Audio | 0 | 2nd August 2006 09:09 AM |
| -:- Earthquake -:- | audioPT | Subwoofers | 3 | 30th October 2004 01:02 PM |
