#21 |
If the bias is set and the amp produces clean output up to clipping, the problem is likely in the differential amplifier stage. Those are the MPS6521s and MPS6523s just after the op-amp that feeds the channel. They need to be replaced in pairs with transistors from the same batch (same date code).
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#22 | |
#23 |
Contact Rockford if you can't find them from any distributors.
If they can't supply them, ask them if there is a recommended substitute.
#24 | |
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch |
#25 |
The transistors with the same part number have to have the same date code.
#26 |
I've found this supplier on eBay "componenttradersllc" for the transistors , has anyone else brought from this supplier ? I've messaged the lady & she said they fit Perry's requirements above. I need to finish my amp so if this sounds fine then I'll go ahead w/the purchase.
Dear primemova, Sure we could do that. What do you want to pay for 60 total? Clarissa - componenttradersllc Subject: has sent a question about item eBay item #150969981782, MPS6523 TO-92 BIPOLAR JUNCTION TRANSISTOR NEW QUANTITY-450 Dear componenttradersllc, Need matched pairs of both mps6521 & mps6523 around 30 of each ? - primemova |
#27 |
I have not bought from them before. I have messaged her a few times.
Give them a try.
#28 |
#29 |
Would you be intrested in sell ing the Power 1000c if call kip at 601 325 0464
#30 |
| Rockford Fosgate Power 650 Mosfet "rejuvification" | pgerry | Car Audio | 16 | 20th October 2012 02:25 PM |
| Rockford Fosgate p10002 Mosfet Cross Reference Help | 2012stankiewicz | Car Audio | 10 | 4th July 2012 10:13 PM |
| rockford fosgate power 650 mosfet | mike49504 | Car Audio | 43 | 24th March 2011 10:21 PM |
| rockford fosgate power 300 mosfet | mike49504 | Car Audio | 26 | 23rd December 2009 04:06 AM |
| Rockford Fosgate/Mosfet | steven123654 | Car Audio | 5 | 2nd September 2009 02:13 AM |
