Rockford Punch 200.2 one channel down? - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 12th November 2012, 11:17 AM   #21
dhamia is offline dhamia  United Kingdom
Hi Perry, I missed the scope, was outbid.
is this any good
290806085883
Item number:
Old 12th November 2012, 02:09 PM   #22
If it's in good working order, it would be OK but you can't tell if it's working properly from that photo.
Old 4th December 2012, 11:21 PM   #23
Quick update on this amp, I replaced all the output
Transistors on the blown side and it now produces a very low sound
The other channel still works fine.
Also I'm still on the lookout for a scope.
Old 5th December 2012, 01:55 AM   #24
Is the audio clean but low or is it distorted?
Have you operated all controls through their entire range to see if the audio output played at a normal level (even intermittently)?
Have you swapped the RCAs to confirm that the signal from both RCAs was the same?
Old 5th December 2012, 04:13 AM   #25
seankane's Avatar
Did you check to see if any of the source resistors were out of tolerance?
Did you check the smd trasistors marked 1A and 2A?
Did you check the smd diodes marked 5D and A7?
Also did you check the SMD resistors within the channel that was blown to see if any are out of tolerance?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 5th December 2012, 11:27 AM   #26
Perry - The audio output is lower than the working side
When wired in mono it makes good power but very distorted
(it didn't make any sound wired in mono previously)
Old 5th December 2012, 11:39 AM   #27
Seankane- can you please mark the on the attached images
[IMG]Click the image to open in full size.[/IMG]
- source resistors
-smd A1 and 2A
-smd diodes 5D A7
smd resistors within the blown channel
Old 5th December 2012, 10:16 PM   #28
The source resistors are the large resistors connected directly to the source leg or each of the output transistors.
The SMD resistors are the tiny surface mount resistors used throughout the amp (like the gate resistors).
The other SMD components he mentioned will have the markings he listed on the face of each of the components. All will have 3 terminals and a black body.
Old 5th December 2012, 10:41 PM   #29
How do I test the smd's
Old 5th December 2012, 10:44 PM   #30
SMD = Surface Mount Device
You test them the same way that you would if the device had wire leads.
Rockford Fosgate Punch 200 IX S Merlington Car Audio 15 2nd September 2012 06:13 AM
Rockford Fosgate Punch 200.4 seankane Car Audio 33 23rd November 2011 11:39 PM
Rockford Fosgate Punch 500x 4 channel seankane Car Audio 48 29th April 2011 11:46 PM
Repairing Rockford fosgate punch 40X2 channel help chipper Car Audio 17 26th August 2010 11:29 PM
bias current on rockford punch 200.4 Ground Zero Car Audio 2 5th April 2010 06:06 PM
Copyright 1999-2017 diyAudio
