Problem Z1!Help!
Problem Z1!Help!
Old 25th October 2012, 09:00 PM   #1
brunogtspl is offline brunogtspl
Default Problem Z1!Help!
Hello,
My DD Z1 amp has a problem during a test spl I replace transistors FQA38n .. and I control the board driver. I change ir2184s 2 drivers, there are 4 zener diode are connected I can not find the corespondance searching on search engines? diodes are marked B2Z or B2L
Can you help me I miss more than its components to re run my Z1. many thanks
Old 26th October 2012, 07:57 AM   #2
I put pictures of the board to see the driver installation!
Old 26th October 2012, 09:07 AM   #3
luka is offline luka  Slovenia
luka's Avatar
Problem Z1!Help!
where are those diodes on board on which one?
any pictures?
I don't think b2z or L is correct, are you sure about that mark?
maybe this will help you, from some other user that made this
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 29th October 2012, 10:06 AM   #4
I have new pictures on B2L diodes or Z are short circuit!
Find this model of diode? Thank you for schemas Luka! there are power PWM
Old 29th October 2012, 10:19 AM   #5
Old 30th October 2012, 03:55 AM   #6
S Merlington is offline S Merlington  United States
Im trying to find the same diodes since the Z1 i have here they are shorted as well..
If i find a part number i will post it.. If you find one before me id greatly appericate it if you would post the part number..
Old 3rd January 2013, 08:06 PM   #7
francesco306 is offline francesco306
hello my name is francesco306 and delight in the repair of amplifiers and I came across the dd z1 someone could provide me with electronic schematics amplifier
Old 3rd January 2013, 09:33 PM   #8
Start a new thread and describe the problems with the amp...
Old 11th March 2013, 07:29 PM   #9
My subwoofer is placed in short circuit and made ​​a short circuit in the FQA 38N30 transistors and the card driver. I check the driver board components there are four IR 2184S
B2L and zener diodes are also short circuit! where can you find them? Thanks
Old 18th April 2013, 11:33 AM   #10
brandes.cm is offline brandes.cm  United States
MBR0520L
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Problem Z1!Help!Hide this!Advertise here!
Digital Designs Z1 S Merlington Car Audio 16 26th September 2012 05:55 PM
Digital Designs Z1 mike49504 Car Audio 21 23rd October 2010 03:46 PM
Another DD Z1 Problem thread dwright27 Car Audio 12 3rd May 2010 05:26 AM
Pioneer C-Z1 pre amp RCruz Solid State 2 18th September 2009 10:13 PM
