Go Back   Home > Forums > General Interest > Car Audio
Old 22nd October 2012, 04:28 AM   #1
seankane's Avatar
Default Rockford Fosgate P500-2
Hello I have a newer P500-2 that Rockford wont release the schematic to yet.
One channel has distortion, any idea where to look? Maybe the A/B driver card?
I posted a pic of the board, it is number 1325-52756-02 2007 model.
The wierd thing is the output on the scope with a 100Hz sine wave scope set at 2ms 20v/d the output looks clean.
When you play a music cd the amp plays ok for a little bit then as the volume is increased the amp cuts out with the red and yellow lights clipping on and off. When the volume is decreased then the channel gets distorted.
I dont understand why it is clean on the scope??????
Any ideas????
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 22nd October 2012, 07:42 AM   #2
I haven't had to repair many of the amps of this type. The only fault that I found was as indicated in the attached image. The fault may be related if the transistor is leaky.
There can be different types of distortion. Not all are as easy to see as clipping or severe under-biasing.
Old 22nd October 2012, 08:43 AM   #3
seankane's Avatar
I will check it out. It seems to only have distortion with a load. It looks clean on the scope.
There is no DC on either bridging terminal.
Old 23rd October 2012, 01:33 AM   #4
As a side note, these daughercards appear to be used in a *bunch* of the newer style amps, I am pretty sure i've seen this same part number in the p300-1, p300-2,p400-2,p400-4 and p500-2, and I'm pretty sure even the power series t600-2/4 amps too...
Old 4th December 2012, 09:21 PM   #5
404Amps is offline 404Amps  United States
404Amps's Avatar
@sean,
I'm having similar distortion on a p300-1 amp. what did you find to be defective on the 500-2?
@ PB,
What is the correct testing procedure for the smd transistor as noted below and in the attached photo?
Ps. I don't have a scope.
Old 4th December 2012, 09:24 PM   #6
On that amp, the transistor was shorted. If you find a direct short between any of the legs of that transistor, it's defective. If it's leaking, you'd have to lift two legs or remove it for testing.
Old 5th December 2012, 04:53 AM   #7
seankane's Avatar
I never went any further on the amp, the customer is in no hurry and I have so many to repair I put it on hold. I will likely pick it up in the next few days, I am trying to get this tiresome punch 800.2 fixed its really wearing me thin!!
rockford fosgate t30001bd dips1982 Car Audio 16 18th July 2012 10:15 PM
Rockford P500-2 heatsink brandes.cm Car Audio 0 27th November 2011 02:08 AM
Rockford fosgate 4.6 X mike49504 Car Audio 14 28th May 2011 03:35 PM
Rockford Fosgate dtisme Car Audio 1 5th October 2010 11:39 PM
Rockford Fosgate 325.1 phreaktor Swap Meet 1 28th February 2008 11:54 PM
Copyright ©1999-2013 diyAudio
