#11 |
yes i would...
#12 |
Will do... Thanks
Let you know the results
#13 |
OK, Installing two more Z44 MOSFETs worked no problem.
Now for the DC off-set problem... Was at 60 mV on the Rt speaker output. After checking the res readings on the darlington pairs (finals) one was way high compared to the rest. Replaced them and now I'm down to about 30mV on the Rt channel. Next I looked at the MPSA06/A56 trans used and started checking the Hfe value on all my new spares and there is quite a spread in values. I picked out the closely matched ones and installed them and that balanced the differential amp much better. I'm next going to check the MPSU07/57 (next stage) and see if I can get it down further. Question though.... I noticed that the +/- 15 coming out of the power supply is reading +15.5 and -16.02. There are zener diodes along with TIP31C/32C for that section of the power supply. On the differential amp section, I noticed that the MPSA06 pare use -16.02 fed through a 3.9k resistor and then to the emitters of that pair and the MPSA56 pair use the +15.5 through the 3.9k to emitters. SEE Part of schematic here.... diyAudio Could this be an issue? |
#14 |
The amp works fine
Special thanks to Perry and 1moreamp for skoolin me on dc off-sets and determining that the engineering on this amp was poor. I learned allot about audio amps on stuff I thought I knew. I felt like I was in first grade .Its all buttoned up so know its off to re-cap the few Soundstreams I have. Thanks all. Oh, When I heat up Q20 (MPSA06) or Q17 (MPSA56), the offset starts going towards 0v from +40mV.
| FS: Zapco DSP6 & Zapco SLB-TP4 | coolnose | Swap Meet | 2 | 25th March 2012 07:48 PM |
| Zapco 150L smps question | amt | Car Audio | 0 | 7th June 2010 09:08 PM |
| HELP!! Looking for Zapco | oldshoolaudio | Car Audio | 6 | 22nd June 2009 09:57 PM |
