OS Mmats D3000.1 repair
Old 9th February 2013, 07:15 PM   #11
Perry Babin is offline Perry Babin  United States
If one end is connected to the source, that's ground. Which legs of the transformer connect to the other end (outside primary, primary center tap...)?
Old 9th February 2013, 07:20 PM   #12
Deadly Sones is offline Deadly Sones  Canada
Deadly Sones's Avatar
Outside primary
Old 9th February 2013, 08:01 PM   #13
In the earthquake amps (that are very similar in design), they use 1.5KE36A transient voltage suppressors.
Old 9th February 2013, 08:07 PM   #14
K thanks Perry. I'll give them a try. Seems like some of these failed miserably, so thought I'd see what should be there. These amps look to have been repaired MANY times.
Old 9th February 2013, 08:27 PM   #15
Should I use 10, or 24 ohm gate resistors for the 3205s? these amps have both. Think I recall you saying that 3205's work well with 47 ohm if I'm not mistaken?
Old 9th February 2013, 09:41 PM   #16
The 3205s will work with any of the values you listed when there is one gate resistor per FET. IF there is only one gate resistor for all of the FETs in each bank, use the 10 ohm.
Old 9th February 2013, 09:46 PM   #17
Yes there is only one for each bank. O.K. I'll get some 10ohm ones. Thank you sir!
Old 16th February 2013, 08:56 PM   #18
K so I have this amp all back together. Rebuilt most of the PS. I reused the outputs that were in the amp after testing them all. When I first powered it up it went straight to protect, then after resetting remote, its been powering on with no protect lights at all and sounds like its oscillating.
I have .-0.191vdc across the speaker terminals. Is that considered O.K. for a 3K amp? It doesn't appear to be pulling excessive current as its only like .6A @ idle with no signal. The Cyclops only had .003vdc across speaker terminals and 3.7a current @ idle. Should I leave well enough alone? or find the cause of the DC? There is .098vdc without remote just battery & ground.
Old 16th February 2013, 10:08 PM   #19
It's greater than what most techs would consider OK. It's not going to cause harm to any speakers that can take the power that this amp can produce. If you want to investigate further, post the DC voltage on all pins of U2.
Old 17th February 2013, 12:11 PM   #20
I definitely wanna try to get the dc as low as possible.
U2 is a LM837M
I have the following DC readings:
1: 7.44
2: 7.44
3: 7.42
4: 14.44
5: 8.48
6: 8.48
7: 7.43
8: 7.34 (not a typo)
9: 7.43
10:7.43
11: 0.000
12: 7.43
13: 7.44
14: 7.44
5 and 6 look high?
OS Mmats D3000.1 repairHide this!Advertise here!
FS MMATS MMATS MMATS zade08 Swap Meet 1 27th April 2013 02:36 AM
Trying to repair MMats 3500.1 bass junkie Car Audio 10 18th January 2010 06:25 PM
non - OS vs OS, for amusement and entertainment only andrew_whitham Digital Source 25 4th October 2006 11:43 AM
I2S DAC OS, or NON OS kostix Digital Source 2 1st May 2005 03:47 AM
Additional hardware os with multiple os filters ? Bernhard Digital Source 0 21st January 2005 08:07 PM
