Go Back   Home > Forums > General Interest > Car Audio
Old 17th October 2012, 07:34 PM   #1
Default Rockford 360.6 - blown power supply MOSFETs
Hi, I have a rockford 360.6 with blown power supply MOSFETS. The amp blew when I was re-routing some wires in the front of the car a few years ago. Possibly related to the pre-amp inputs or +12v remote turn on wire?
I have some basic electronics knowledge, and tried replacing all of them (Motororla MTP50N06V) and as soon as I applied power the new ones burnt up.
Does anyone have a schematic for this amp, or any guidelines on where to look?
Thanks!
Old 17th October 2012, 10:07 PM   #2
If you haven't done so, read the entire basic amp repair page (link in sig line below). That will help you with the basics.
Old 18th October 2012, 06:41 AM   #3
seankane's Avatar
Did you make sure the gate resistors for the power supply fets were within tolerance and had a good connection?
Did you replace the pnp and npn driver transistors for the power supply fets?
Also did you confirm there were no solder bridges between the legs of the power supply fets?
Post a pic of the board where you did the repair.
I think I have the schematic somewhere I will look.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 19th February 2013, 04:28 PM   #4
Hi guys...
Thanks for the insight. After posting this thread, I noticed a burnt trace on the board near the power supply PWM controller chip.
Here are some pics:
Are there any equivlent replacements for the MTP50n06v that I can use?
Old 19th February 2013, 04:40 PM   #5
seankane's Avatar
You can still purchase those MTP50N06V's brand new.
I would use IRF3205 and change the gate resistors to 47 ohm.
Also you need to change the drivers to after a second failure they are sure to be shorted.
Looks like in the pic they would be marked 1GM and 2GM which are MMBTA56 and MMBTA06. The transistors in location Q4, Q5, Q6, Q7.
Old 19th February 2013, 04:47 PM   #6
seankane's Avatar
E-mail me at seankane89@hotmail.com if you want the schematic.
Old 19th February 2013, 04:48 PM   #7
Thanks for the info. Do you have any ideas why the trace near the PWM controller could have blown? Do you think it could have been related to static in the remote turn on line?
Help repairing my power acoustik CPT1 3200D blown mosfets, ect???? brenttheman123 Class D 10 10th October 2012 02:12 AM
Help repairing my power acoustik CPT1 3200D blown mosfets, ect???? brenttheman123 Class D 0 9th October 2012 02:32 AM
Rockford Fosgate Punch 360.2 missing parts Mote Car Audio 1 12th June 2012 09:36 PM
rockford fosgate t2000-1bd blown power supply mosfets 2sheezy Power Supplies 3 4th October 2011 07:59 PM
rockford fosgate t2000-1bd blown power supply mosfets 2sheezy Car Audio 15 4th October 2011 12:50 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
