diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   Hifonics Brutus BX 2005d (http://www.diyaudio.com/forums/car-audio/221601-hifonics-brutus-bx-2005d.html)
seankane 15th October 2012 06:50 PM
Hello I have not worked on a hifonics amp before, can someone tell me what this amp usaes for power supply fets and output fets? I have a broken one on the way and want to get a start on getting parts together.
Perry Babin 15th October 2012 06:57 PM
The BXi2006 used FQP85N06s but I'd likely use 3205s as subs. I don't have any photos of the 2005 so I'm not sure what they used.
The protection circuits in these amps are pretty good and I rarely see a blown power supply. Are you sure that this one has failed?
seankane 15th October 2012 07:02 PM
The guy said it is broken and something inside is clunking around, so I am assuming a capacitor has come desoldered from somewhere and is floating around in there. I didnt get many details. I just want to be prepared.
I only paid $55 for the amp so I figured I could give it a shot, seems to be a pretty powerful amp from looking at the specs.
I owned a brutus 1500 before and had it on 3 jl audio w3's and was very impressed.
I wonder what would be the difference in the BX2006 and BX2005 just different year models you think?
seankane 15th October 2012 07:04 PM
1 Attachment(s)
Here is a pic.
Perry Babin 15th October 2012 08:37 PM
I don't know if there will be a difference. For at least one model, there were two completely different boards so I don't know how consistent that they will be.
seankane 26th October 2012 07:39 PM
Well I recieved the amp today. All the power supply fets (FQP85N05) have been removed. Someone has attempted a repair on this unit. The gate resistors they installed are 22ohm but are to big and poorly installed.
Were the originals 22 ohm and if so were they 1/8 watt?
There are also some transistors poorly soldered on a driver board near the rail caps, dont know if there the right ones they are marked A1266 and there is only 3 of them or what they are suppose to be????
I will be replacing the power supply fets with IRF3205 and 47 ohm through hole resistors just need to know if they are suppose to 1/8 watt or what looks like they used 1/4 watt and they are to big for the spot on the board.
Any advice would be great and anything else I should be looking for asside blown outputs???
Perry Babin 26th October 2012 09:05 PM
1 Attachment(s)
I don't have anything on this amp but many of the amps that used 1/8w gate resistors used 22 ohm resistors. The ones with 1/4w resistors tended to use 47 ohm resistors.
If the layout is similar to the attached photo, there should be 4 1266s. There is one 1266 and one diode to drive each of the 4 banks of FETs.
seankane 26th October 2012 09:22 PM
2 Attachment(s)
This amp is different and I have not confirmed but dont think its a 4080 amp. The parts yours show are not in this amp and it has a driver card next to the rail caps.
Pic 1 of board
Pic 2 of driver card with 3 1266's soldered on and I dont know if they are original I would say not by looking what do you think???
Perry Babin 26th October 2012 10:55 PM
I've never seen that board with those transistors. This post shows the board with the original transistors.
bl4ckw1d0w 26th October 2012 11:25 PM
I have that same exact board, same driver card, everything internally. The only difference is mine came in a 2006 chassis. It has 1/4 Watt 47k ohm resistors. IC1 is a KA7500BD. If you need any references on the board I can be of some help.
Copyright 1999-2017 diyAudio
