Hifonics Brutus BX 2005d
Old 13th November 2012, 09:31 AM   #81
seankane is offline seankane  United States
seankane's Avatar
I checked again with relatively the same result
E: .505 vdc
C: .762 vdc
B: .003 vdc
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 13th November 2012, 03:57 PM   #82
Perry Babin is offline Perry Babin  United States
There is something has seemed odd but I didn't want to ask you to recheck all of the voltages. The emitter of that transistors should read 0.00v since it's directly connected to ground. The small errors in voltage could be critical in troubleshooting because the threshold voltage for the transistors is only about 0.5v. Why to you read about 0.5v on the points that should essentially have no voltage on them?
Old 13th November 2012, 06:52 PM   #83
seankane's Avatar
I am not sure, are you asking me? I dont know why something directly connected to ground would have voltage.
Q3 has been replaced twice so I doubt its that but Q4, Q5, Q6 could be defective or leaky I suppose. I have not found any burned traces so far.
Maybe something is backfeeding those transistors voltage???
Old 13th November 2012, 10:49 PM   #84
What is the resistance between pin 7 of the 494/7500 and the point where you had the black probe?
What point did you have the black probe on when you posted the voltages previously?
Old 14th November 2012, 07:40 AM   #85
seankane's Avatar
The resistance is 000.1 to 000.3 ohms pretty steady sometimes jumps around a bit.
I was using the amps ground terminal for the black probe while measuring the transistors.
Old 14th November 2012, 08:38 AM   #86
Power it up again. Place the black probe in the amp ground. What is the DC voltage on pin 7 of the 494?
What is the DC voltage on the emitter of Q3?
They should both be essentially 0v (down to a few millivolts) and should be the same.
Old 14th November 2012, 08:46 AM   #87
seankane's Avatar
The emitter of Q3 remains the same.
Q3
E: .508 vdc
494
Pin7: .010 vdc
Old 14th November 2012, 09:31 AM   #88
With no power applied, what's the resistance between the emitter of Q3 and pin 7?
Old 14th November 2012, 09:35 AM   #89
seankane's Avatar
152.9K
Old 14th November 2012, 10:39 AM   #90
Check your email.
Hifonics Brutus BX 2005dHide this!Advertise here!
Hifonics Brutus BX1605D mike49504 Car Audio 3 25th July 2011 05:12 AM
hifonics brutus BXI1500D elev8rsh0es Class D 1 8th February 2011 04:47 PM
Hifonics Brutus lee1976 Car Audio 3 20th July 2010 11:19 AM
Hifonics BXi2006D Brutus! Formas Class D 0 30th August 2009 05:25 AM
hifonics brutus bxi1206d ray9043 Car Audio 2 30th March 2008 05:36 AM
