Hifonics Brutus BX 2005d
Old 13th November 2012, 08:11 AM   #71
seankane is offline seankane  United States
seankane's Avatar
oops just got it off and its a 100uf 16v
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 13th November 2012, 08:16 AM   #72
Perry Babin is offline Perry Babin  United States
You can simply remove it. That will eliminate the delay. I wouldn't connect speakers when powering it up. It could produce a loud pop.
Old 13th November 2012, 08:23 AM   #73
seankane's Avatar
It measured 89uf on the meter does that mean its defective since its a 100uf cap?
Old 13th November 2012, 08:26 AM   #74
seankane's Avatar
I accidentally shorted the emitter and collector of Q3 when doing some testing and the relay clicked. Does this mean Q3 is leaky and how could it be since its new????
Old 13th November 2012, 08:38 AM   #75
Shorting the collector and emitter should have prevented the relay from engaging by switching the other two transistors off.
89uf is within tolerance for most electrolytics (which are often 20%).
Are you sure that the relay didn't click immediately when you powered up the amp?
Re-check to see if you still have 14v on both ends of the diode near the relay.
Old 13th November 2012, 08:42 AM   #76
seankane's Avatar
Yes I have 14.50 on both ends of D201 the diode next to the relay. The relay is not clicking when the amp powers up but if I short the emitter and collector it clicks on and stays on......I dont get it.
Old 13th November 2012, 08:52 AM   #77
How did you short the collector and emitter accidentally? They're on opposite sides of the body of the transistor.
Old 13th November 2012, 08:56 AM   #78
seankane's Avatar
The top pin and middle pin are both the collector, they are connected underneath the transistor. When I went to test the voltage on the emitter I accidentally touched the collector at the same time.
Old 13th November 2012, 09:26 AM   #79
Are you sure that you had the voltage on the base of Q3 right when you posted the voltages?
Old 13th November 2012, 09:28 AM   #80
seankane's Avatar
I replaced Q3 again with the same result no relay engage. I will check the voltages of Q3 again and re-post then to confirm.
Hifonics Brutus BX 2005dHide this!Advertise here!
Hifonics Brutus BX1605D mike49504 Car Audio 3 25th July 2011 05:12 AM
hifonics brutus BXI1500D elev8rsh0es Class D 1 8th February 2011 04:47 PM
Hifonics Brutus lee1976 Car Audio 3 20th July 2010 11:19 AM
Hifonics BXi2006D Brutus! Formas Class D 0 30th August 2009 05:25 AM
hifonics brutus bxi1206d ray9043 Car Audio 2 30th March 2008 05:36 AM
