Hifonics Brutus BX 2005d
Old 7th November 2012, 06:24 AM   #31
Perry Babin is offline Perry Babin  United States
I don't know if both will work. I'd use whatever the originals were. If you want to know if both will work, try both and test thoroughly under heavy loads.
Old 7th November 2012, 06:31 AM   #32
seankane is offline seankane  United States
seankane's Avatar
I replaced all the irf640N's and powered up the amp without the driver board installed, everything seems fine no dc voltage on the center legs of the 640's.
Does this mean likely Q7, Q11, Q19, Q22 are possibly leaky or shorted??
as replacements all I have on hand is MMBT3904 and 3906 and will those work for replacements since they are all the same pin configuration? I have a56 and a06 but I think the a06 is different pin configuration unless my old notes are wrong?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 7th November 2012, 06:53 AM   #33
seankane's Avatar
Looking at the data sheet I dont know if the others can handle the voltage the a42 and a92 are designed for???
Old 7th November 2012, 07:32 AM   #34
I wouldn't try the 390xs. The MMBTA42/92 are very commonly used and it would be good to have them on hand.
The transistors open, short and leak. Sometimes, they have open junctions when tested on the board and after you remove them, they check OK (but they're not).
Old 7th November 2012, 07:38 AM   #35
seankane's Avatar
OK ordered 100 each from mouser have them Saturday maybe Monday for sure guess this amp is on hold till then!!!
Likely since the 640 do not have any voltage on the center leg eveything is ok on the main board?
Everything I have tested so far is within tolerance.
Old 7th November 2012, 07:42 AM   #36
I can't say that everything is OK but it would appear that none of the outputs are leaky. They should read ~100k between legs 1 and 3 and you should read 2x the gate resistor value (10 ohms x2?) between the gate legs of the parallel transistors.
Old 7th November 2012, 08:02 AM   #37
seankane's Avatar
I do read 20 ohms between parallel outputs all the way across on both sides.
I read 24.80K ohms between legs 1 and 3 of every single output on the board.
Old 7th November 2012, 08:35 AM   #38
24k is probably right if there are 4 parallel transistors. There is a 100k resistor on each transistor.
Old 7th November 2012, 09:02 AM   #39
seankane's Avatar
Yes each group has four fets. There are 4 9640's and 4 640's on each side of the amp with seperate power supplies but one pwm driver card running both supplies. I am asumming this is a dual mono block amp??
Old 7th November 2012, 09:26 AM   #40
It has 2 groups of FETs that drive a single output.
Hifonics Brutus BX 2005dHide this!Advertise here!
Hifonics Brutus BX1605D mike49504 Car Audio 3 25th July 2011 05:12 AM
hifonics brutus BXI1500D elev8rsh0es Class D 1 8th February 2011 04:47 PM
Hifonics Brutus lee1976 Car Audio 3 20th July 2010 11:19 AM
Hifonics BXi2006D Brutus! Formas Class D 0 30th August 2009 05:25 AM
hifonics brutus bxi1206d ray9043 Car Audio 2 30th March 2008 05:36 AM
