Hifonics Brutus BX 2005d
Old 30th October 2012, 08:04 PM   #21
seankane is offline seankane  United States
seankane's Avatar
I called maxxsonics today, and they dont stock the driver board nor do they sell internal parts for their amps.
I asked for a schematic and I got a maybe, I am suppose to call tomorrow and speak with a guy and tell him my "story".
Since its not a current model I did get a maybe. They said the last time they released one someone copied it and started building amps with it, they didnt say who or what but whatever.
So I called Mouser and ordered the 2SB1260's and they will be here this week.
I will keep you posted on the schematic results it would be way cool if they will give it to me. I am not looking to copy their amp and start building brutus amps but it would be nice to have for repairs and such.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 30th October 2012, 09:53 PM   #22
Perry Babin is offline Perry Babin  United States
If you get a diagram from them, that would be very surprising. It would be nice to see some of these manufacturers start to relax. They should realize that anyone who wants to copy a design can easily do it, with or without the schematic diagram.
Old 31st October 2012, 01:27 AM   #23
noobies is offline noobies
Ohh... snap. hopeless for me to get a new driver board too then.
It's a bad support for customer. Because it's an old model and not current model still we can't have the schematics too. I guess maybe because they ask third party to manufacture their amps (OEM)?
Old 2nd November 2012, 12:30 AM   #24
Most of the amps are made by a handful of build houses. There are unique designs like those in Rockford, JL, newer Kicker and a few other amps. A lot of other amps use one of 2 or 3 designs that vary very little.
Old 6th November 2012, 09:17 AM   #25
seankane's Avatar
Few questions Perry
1: Installed new drivers on pwm board and re-installed board onto main board. Hooked up power and ground and remote. Blue LED came on and square wave on all gate pads......this is ok?
2: Installed all gate resistors and power supply fets, checked for bad connections by holding one probe at the end of the gate resistor and other probe on gate leg and all read near or 47 ohms and also checked for solder bridges but did not find any.....this is ok?
3: Removed shorted output fets and left the rest in the circuit....this is ok?
4: Not being that familiar with these amps is it ok to power up out of heat sink like I would a rockford amp??
5: Any special precautions I should take or anything else I should check before applying power?
Thank You
Old 6th November 2012, 06:18 PM   #26
seankane's Avatar
I powered up the amp all was well then poof went the outputs!!!
I can leave all the 9640's installed and it powers up fine, when I try installing the 640N's they blow instantly.
I have posted a pic of the audio driver board, you can see the drive transistors but I am not sure what is what.
There are 4 marked DK QR and 4 marked AG QR.
Old 6th November 2012, 11:10 PM   #27
#25:
1 and 2, yes.
3. Generally, yes but you have to make sure that none of the rest are leaking.
4. Yes if you monitor the temperature of the heatsink mounted components until you see if any are heating up.
5. Nothing that you normally wouldn't check.
The FETs should not have
#26:
DK = 2SC4672
AG = 2SA1797
Was the driver board in the amp when the FETs failed?
Old 7th November 2012, 05:30 AM   #28
seankane's Avatar
Yes the driver board was installed, it is removed now. Should I replace the fets and power up without the driver board installed?
Could some of the DK or AG being leaky or defective cause the 640N's to blow?
The amp idles fine and has a nice square waveform on the power supplt gates. It is producing positive and negative rail voltage of around 80v and all the op-amps have positive and negative supply voltage.
I am thinking I have an issue with the driver board???
Old 7th November 2012, 05:43 AM   #29
Q7, 11, 19 and 22 are generally the problem on this driver board.
I've never seen any of the AG/DK transistors fail on these boards but that doesn't mean that it couldn't happen.
I'd reinstall the outputs with no driver board and confirm that there is no DC voltage on the center legs of the outputs.
Old 7th November 2012, 06:00 AM   #30
seankane's Avatar
Will do is imperative I use 640N or will 640 work? I have both just wondering???
Hifonics Brutus BX 2005dHide this!Advertise here!
Hifonics Brutus BX1605D mike49504 Car Audio 3 25th July 2011 05:12 AM
hifonics brutus BXI1500D elev8rsh0es Class D 1 8th February 2011 04:47 PM
Hifonics Brutus lee1976 Car Audio 3 20th July 2010 11:19 AM
Hifonics BXi2006D Brutus! Formas Class D 0 30th August 2009 05:25 AM
hifonics brutus bxi1206d ray9043 Car Audio 2 30th March 2008 05:36 AM
