#21 | |
#22 |
Post the voltages again. Copy and paste the following for each IC. Look up the datasheet for the IC for the pin numbering scheme or look at the audio troubleshooting page of the tutorial, items 12-15.
IC# Pin 1: Pin 2: Pin 3: Pin 4: Pin 5: Pin 6: Pin 7: Pin 8:
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#23 | |
IC# U15 Pin 1: 15.2v Pin 2: 11.55v Pin 3: 0.31v Pin 4: -15.88v Pin 5: 0.32v Pin 6: 12.14v Pin 7: 15.23v Pin 8: 15.92v IC# U14 Pin 1: 0v Pin 2: 0v Pin 3: 0v Pin 4: -15.90v Pin 5: 0v Pin 6: 0v Pin 7: 0v Pin 8: 15.93v I have found the part you refer to in 12-15, also in the beyond the basics. I just need to read it another few times for it to sink in. Cheers |
#24 |
U15 appears to be defective.
#25 |
Thankyou, I have ordered a couple of the op-amps.
#26 |
op amp has arrived. From a company called littlediode.com
#27 |
I have now replaced U15. The amp is better, but still a bit unstable. Looking at the bias on the outputs with the scope, It varies up and down like it is trying to get back to 0v, and sometimes it throws into protect.
this is on ch4, so is the same side of the amp. The ch1-2 side bias is dead flat on the speaker terminals. I will retest U15 |
#28 |
Post the DC voltage on all pins of U14 and 15 if you can't find the problem.
#29 |
There is some issue related to the Bassboost area of the preamp. U15 is the opamp involved.
All the other opamps on the Ch3-4 preamp board show -15v and +15v on pins 4 and 8, and 0v on all other pins. This includes U14. U15 has different voltages when the switch is changed from 0db to +6 and +12db IC# U15 @0db Pin 1: 1.5-1.8v Pin 2: 1.3-2.2v Pin 3: 0.42v Pin 4: -15.88v Pin 5: 0.42v Pin 6: 0.4-2v Pin 7: 1.8-2v Pin 8: 15.92v With the 12db Bassboost selected, the voltage varies on the pins. I have taken a pic of the scope from pin4 as a example: DSCN4405.JPG Its a bit hard to read, but it switches every 0.45 secs (0.1 sec vertical divisions), with voltage around 7v and -7v (10v horizontal divisions) With the 6db Bassboost selected, the voltage varies on the pins. I have taken a pic of the scope from pin4 as a example: DSCN4406.JPG Its a bit hard to read, but it switches every 0.5 secs (0.1 sec vertical divisions), with voltage around 9v and -9v (10v horizontal divisions) No other settings seem to affects the opamp |
#30 |
The scope captures are labelled wrong in the post above, the top pic is 12db but it switches every 0.5 sec and voltage is +-9v.
The lower pic above shows 6db and switches every 0.45sec and voltage is +-7v. Sorry about that... From post 18 this thread: Attachment 307693 and a newer clearer pic, most of the parts in this area seem to have a oscillating voltage.The switch at bottom right is the bassbost DSCN4408a.JPG Thanks for looking. Last edited by wrxer; 18th November 2012 at 01:06 PM. |
| Soundstream 500 resistor help | slack051 | Car Audio | 23 | 19th September 2012 03:53 PM |
| Soundstream Rubicon 1.2500 in protect | bigpun4fubu | Car Audio | 57 | 7th August 2012 12:25 AM |
| Help pls, need schematic SOUNDSTREAM LW4.620 | Alexeus | Car Audio | 0 | 21st January 2011 08:16 AM |
| Soundstream 500 | Robcrx | Car Audio | 7 | 15th March 2010 01:45 PM |
| Hafler DH-500 Protect Circuit Problems | wangro81 | Solid State | 4 | 9th October 2006 11:02 PM |
