40hz boost question
40hz boost question
Old 12th October 2012, 03:40 AM   #1
90scaraudio is offline 90scaraudio  United States
90scaraudio's Avatar
Default 40hz boost question
Could someone explain how this circuit works to boost 40hz. Its a variable boost and I don't understand how the second op-amp provides gain. I've circled the portion in red. Ok, my brain hurts! Does it pickup its source from ground and pass through 56k into non-inverting then out of the op-amp through 2.7k and 2.2uf then into the variable resistor?
Old 12th October 2012, 10:27 AM   #2
OOpppss..... All op-amps are TL072.
Old 12th October 2012, 11:28 AM   #3
demeterart is offline demeterart  Greece
demeterart's Avatar
the op-amp in red is an inductance emulator of 6 something Henries with about 53K in parallel and 2.7K in series with the parallel RL. along with the 20K pot acts as a variable NOTCH at about 40Hz. a really awkward design!
Old 12th October 2012, 12:19 PM   #4
OK, thanks much. So I bet there is a better design and will have to research.
Old 12th October 2012, 01:45 PM   #5
Perry Babin is offline Perry Babin  United States
You can build a common EQ boost/cut circuit and only use the boost (one example).
This circuit uses three filters to increase/decrease the feedback for a range of frequencies. The more feedback, the more cut. Less feedback results in greater output at that band.
The old Rockford circuit is relatively simple but requires a reverse log pot to make it easily adjustable.
Old 12th October 2012, 09:59 PM   #6
Thanks... I should have read Elliott Sound Products as there is a nice explanation on this... Parametric and Sub-Woofer Equaliser
The particular crossover I drew this from I've had laying around for about 15 years. I benched it with a sig gen and scope. With 1 volt in @ 40hz and no boost it puts out about 1.2 volts. (This is just one of the channels.) When the boost is turned up to full the output goes to 7 volts with a decent looking sine-wave. I thought, that's a heck of a boost!
Scott
40hz boost questionHide this!Advertise here!
[enquiry] Treble Boost/High frequency Boost circuitry elnino86 Parts 2 18th December 2008 01:33 PM
40hz seems too much Kelloggrice Subwoofers 7 29th March 2007 01:30 PM
Preamp question/ input gain boost 3-LockBox Class D 2 13th June 2006 04:23 AM
Bass boost - dumb question candidate Dave Jones Multi-Way 16 5th August 2003 01:37 AM
12 db bass boost 40hz vs 45hz...? ChesterFuzzin' Multi-Way 7 22nd November 2002 03:22 AM
