#41 |
Well yes you will need to buy replacement parts for all of those shorted transistors, and you can find them thru the links I provided you earlier in this thread. < see post #24 > Just click on those links and put your part numbers into the search bar and click and VIOLA !!! who, and how much and how to buy them will pop up on your screen.
As for Silicon heat sink compound well your local radio shack will have it in very small tubes. it's quite expensive. So you will not want to waste it, so go sparingly with it. I buy bulk and get bulk rates on things so when I buy I get 400 gram buckets and you don't want to know how much they retail for . So you need to go shopping for clamp materials at your local hardware store and Silicon heat sink compound at Radio shack or any of the large suppliers you will see when you search for you transistors on those links I posted to you earlier. Do not use Arctic silver or any other of those high price metal based compounds you see in computer stores. CPU's are isolated from their metal case parts so using silver and copper compounds are OK, but these transistors carry power on their metal tabs and the White silicon heat sink compound you want is non conductive of electricity while those metal based compounds will conduct electricity along with heat. That would short out all of your hard work so don't go fancy just use plain white silicon heat sink compound, ONLY... |
#42 |
ok i got my brackets made for the amp i'll post a pix tommarrow and do u have those parts? i m willing to buy sence u know what parts i need and stuff? if not i'll look them up and see
#43 |
Morning Joey, I don't sell parts on the DIY, I just try to help out with the tech part of what your doing. Yes I have all the parts you need, but you can get them just about anywhere on your own for reasonable prices. If your having trouble please just PM me a email and I will try to sort it out for you....
#44 |
ok for now i'll just pull the ones off the other ppi amp that are good bc i tested them and i dont feel like waiting for parts, right now. next is is there a easier way of desoldering the legs off the board and getting the solder out of the holes so i can put the good transistor in place, so far i used the stupid braided copper that somebody sujust using and it sucks. thank you for ur time and helping me out so again here is what i pulled out of good ones (Q7 Q8 Q9 Q10 Q12 Q17, do i need the resistor right behind the rca too if so i can probably get those at a radio shack?
#45 |
Desoldering braid isn't very good for clearing holes. If you must use it, flux makes it work better.
If you want a good desoldering pump, order an Edsyn DS017. I'd suggest that you buy from a reputable distributor or directly from Edsyn. Some of the ones on eBay are likely to be counterfeit. If you keep the DS017 clean and don't abuse it, it will probably work well for you for 10 years or more.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#46 |
Thank you perry. I was going to buy a soldering vacum pump but the radioshack lady spoked to me out of buying one so ill pick one up thank you again
#47 |
Don't buy any desoldering pump except the one I suggested. Most others are useless.
#48 |
Q7 thru Q11 are 2N6490 transistors. Just use that number for replacement parts. It's all you need to ID correct parts replacement. If you look at the plastic tops of those devices you will see that number etched/printed into the surface of them. Q12 is a driver transistor and they varied by the model. The unit I have in front of me uses 2SB1186A transistor. You should check yours to see what number it uses.
The resistors are 10 ohm 2 watt ceramic type resistors. As I spoke about earlier they can be found on ebay if your search engines don't turn up any responses to that part inquiry. Here is a link to a guy in Arizona that has your 10 ohm resistors if your local shops don't have it. 5 Pack 2 Watt 5 Metal Oxide Power Resistors 10 Ohm | eBay Would you also post a close up in focus picture of the large resistors near all the failed transistors just under the large ground bus bar ? if all of the these transistor burned out some of those emitter resistors could have heated up and changed value or opened up also. So please look at them and measure them with your meter if possible. They should all read the exact same on your meter. IF they look ok < no signs of heat damage > and all read the same then your likely good to go there and they will probably be ok. But you should check them just to be sure... If your still having trouble finding parts just Private Mail me, and I will guide you in private mail on the search. Perry Is very much correct about you needing a proper desoldering tool. I use them and solder wick, along with electronic grade liquid flux < you can get this at Fry's electronics or any supplier that has GC electronics chemicals. You can use acetone and q-tips to remove and residual solder flux contamination. Acetone can be had at your local hardware supplier in the paint department. They also have denatured alcohol and it too could be used to clean up your board after work is completed. Careful with these chemicals, please use adequate person protection when using solvents and other chemicals related to electronics repair work! Last edited by 1moreamp; 16th November 2012 at 07:34 PM. Reason: Q12 |
#49 |
You should also post a clear close up pic of the ceramic vertical card facing these bad outputs. Perry has a tutorial on how and what to look for on these SIP modules. it is likely that a resistor has opened up on the module and it must be repaired like you see in Perry's tutorial IF its has sustained damage as I suspect it might have.
This module can be damaged beyond repair in some cases. if this has happened you will need to find another SIP modules to replace this one, and they can only be found on other amps as they are not made any longer. Occasionally you will see them posted for sale on Ebay, but that is getting more and more rare these days. |
#50 |
well i have a exact same amp i have two ppi art a600.2 one im working on and the other i'm using for parts or i like to get one going
| Ppi a600 | wondernutz | Car Audio | 12 | 30th November 2011 01:25 PM |
| PPI a600 channel | carlinux | Car Audio | 9 | 6th June 2011 11:04 AM |
| mtx 4250d powers on but lights out when sub hooked up | ford06f150 | Class D | 4 | 1st June 2011 11:37 PM |
| Ppi a600 | mike49504 | Car Audio | 3 | 21st March 2010 01:44 AM |
| Ppi A600 | npenson | Car Audio | 4 | 27th August 2008 10:36 PM |
