Hi all
I am working on a sound stream amp the cover is missing so i dont no the model.It look exactly like a spl fx1-5500d i had here last week.It has the exact same board.This amp came in with one rail cap with a split at the top.I replace it but am not getting good negative rail. +75.23v and -27.38v.I pull center leg on the - rectifier and i get 77.23v on it.Any help will be good. |
#2 |
No excessive current and nothing is geting hot.
#3 |
Does the rail voltage become balanced if you place the black probe on the secondary center-tap (rectifier in the circuit)?
Post a photo of the board or a link to a photo of the identical board if you posted one in your other thread.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#4 |
yes amp about 47.26 on both rails when i used center- tap for ground point.
The 15v -reg is bad am geting 5v out from it.I will change it and repost later. |
| Sound stream usa 364 | builtyodas | Car Audio | 2 | 7th February 2012 04:11 PM |
| sound stream xta720.4 *protect | ian33 | Car Audio | 4 | 29th August 2010 06:52 PM |
| Sound Stream SA245 repair help | grjr | Car Audio | 4 | 29th December 2008 07:25 AM |
| Sound Stream Mc-245, No Power!..help! | JT_mechanic | Solid State | 0 | 27th May 2008 10:37 PM |
| sound stream any good? | 1needforspeed | Car Audio | 6 | 20th March 2005 02:09 PM |
