Help w/ Class D driver
Old 7th October 2012, 02:04 AM   #1
Tom7227 is offline Tom7227  United States
Tom7227's Avatar
Help w/ Class D driver Send a message via AIM to Tom7227
Default Help w/ Class D driver
I am working a DC Audio 12K amp, tring to get a handle on the problem. The amp isn't in protect, all rail voltage are there. No oscillation...
Has any body seen this type of class d driver board, or could possible help identify the IC that are ground off,
Thank You
Old 7th October 2012, 02:37 AM   #2
timwebb is offline timwebb  United States
ive never seen that. can u get any voltages off the pins of those ic's?
Old 7th October 2012, 10:45 PM   #3
whizgeek is offline whizgeek  Ireland
look like mosfets.
If theres a number of pins connected together ie. 3 then they are probably single devices.
If there a 2 x 2pins connected, they are probable dual
Old 8th October 2012, 02:24 AM   #4
Perry Babin is offline Perry Babin  United States
It's likely 2 op-amps (or one op-amps and one comparator) and a driver IC like the IR2184S.
Help w/ Class D driverHide this!Advertise here!
DLM4000 class D driver board pergo Car Audio 24 17th October 2017 03:13 AM
Amplifier for driver... what class? nonsuchpro Solid State 0 5th October 2011 01:48 AM
1500W RMS Class D PCB - which Class D Driver Chip is it ? mosfetsound Class D 11 1st April 2011 11:17 AM
6GE5 in driver service for class B P-P rsumperl Tubes / Valves 0 4th February 2010 11:33 PM
Class D driver epilot Class D 7 31st August 2006 07:49 PM
