Go Back   Home > Forums > General Interest > Car Audio
Old 5th October 2012, 11:12 AM   #1
timwebb is offline timwebb  United States
Default kx kicker 1500
I got one of these to fix... I got the amp to power up and play. When the bass hit its really distorted. But at low volume it plays ok. Any thoughts on what to check?
Old 7th October 2012, 05:05 AM   #2
i traced it back to the ir4426 thats putting out the bad drive signal on half of the outputs. do these ic's normally fail?
Old 8th October 2012, 02:12 AM   #3
Are you sure that this isn't a ZX amplifier instead of a KX. I don't remember the 4426 being used in the KX series amps.
I've never seen one fail in the ZX series amps but I haven't had to repair many.
Old 8th October 2012, 02:23 AM   #4
oh yes its a zx.
Old 8th October 2012, 02:25 AM   #5
the amp plays fine but there is a bad signal coming from the one on the right.
Old 8th October 2012, 02:34 AM   #6
Post a photo of the bad signal.
Old 8th October 2012, 02:44 AM   #7
volt/div 1 time/div 5us
Old 8th October 2012, 10:14 AM   #8
Please read the 'Best Initial Settings' section on the oscilloscope page (page 73) of the site and re-post the waveform.
Old 21st October 2012, 03:08 PM   #9
Old 21st October 2012, 03:40 PM   #10
Is that AC or DC coupling? You need to use DC coupling. You also need to set the 'variable' to the cal position (fully clockwise).
You also need to post the settings for the vertical amp and timebase on the scope. In an earlier post, there was a '1' in the scope settings that you posted. I don't know what this was. If it was 1v, there is a real problem. If it was 1v but you're using a 10x probe, that would make more sense and the actual vertical amp setting would be 10v, not 1v.
Kicker Kx 500.2 Amp. Desafinado Car Audio 29 29th December 2012 08:31 PM
Help identify smd in Kicker KX 1200.1 Randy62 Car Audio 8 17th February 2012 09:10 AM
Kicker KX 2500.1 scratched serials! XxGoKoUxX Parts 1 9th May 2011 01:32 AM
Kicker Amp Kx 600.4 Not Kicking MYLEY Car Audio 0 17th February 2006 03:11 PM
Kicker: KX vs. SX NaftaliG Car Audio 0 11th December 2004 08:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
