#11 |
motronix: is the MMBTA06L the replacement for the MMBT3904L?
#12 |
Also, I haven't counted recently but what if I have lost a couple of the thermal pads that are sandwiched between the FET's and the heatsinks? Can I just use thermal paste? I have a tube of Arctic Silver Ceramic from a PC I built a few years ago. My concern would be consistency in thickness. Are those pads easily found? I see that digi carries thermal pads but I don't have a micrometer to measure them to be able to order the right thickness and size...
#13 |
No you cant, you must have the anodized aluminum pads, or you can use a kapton tape as long as the heat sink is smooth and nothing will protrude through the tape and touch the fets.
If you just use paste the fets, regulators, and rectifiers will short to the heatsink and the amp will go "POOF"!!!
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch |
#14 |
I sure hope I can find all those pads!
#15 |
Order THIS and cut to size or use mica insulators (D-K #4671).
I'd suggest using standard heatsink compound.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#16 |
I have the insulators send me a PM and we can discuss getting them to you.
#17 |
So I lost ONE! One stupid pad! sean I'll send you a PM with my email address. Are they RF originals? I'd only want 2 of them so they could most likely be sent thru a letter envelope. How does $1 "shipped' work for a pair? Check your inbox. Thanks!!!
Anyone want to help me repair my wife's elliptical machine? I plugged it in using a too high voltage power supply and fried some components on the board. A new replacement board is $200 and we only paid $350 for the whole thing! If not here, where can I post for help? I've found two obviously burnt components, one of which is a resistor. |
| rockford 200ix | hifonics hugh | Car Audio | 11 | 30th May 2012 12:02 AM |
| Another Rockford Fosgate Punch 200ix repair | cebby | Car Audio | 26 | 25th May 2012 11:02 PM |
| Assistance on B&W DM1200 crossover repair? | llimbo | Multi-Way | 4 | 27th May 2011 05:09 PM |
| Laser Pickup´s M52103FP RF-Amp instead of older CX20109 RF-Amp | Salar | Digital Source | 2 | 25th July 2010 05:44 PM |
