Orion 2150GX Repair Help
Old 6th October 2012, 02:54 PM   #41
90scaraudio is offline 90scaraudio  United States
90scaraudio's Avatar
knil7777....
I think the spec sheet says its stable to 4 ohms stereo, so, normally when you bridge it, the stability of the amp will only handle a max load of 8 ohms. One of my amps says its stable to 1/2 ohm stereo but in mono its 1 ohm stable. Some one tell me I'm wrong
Just don't want that old thing to blow up again!
Scott
Old 6th October 2012, 04:07 PM   #42
knil7777 is offline knil7777  United States
Thanks Scott, I studied that instruction file on the bridge you sent me and it was hard for me to determine. It looked like it had one summed mono config with the 2-8 ohm speakers wired in parallel but it did not specify which specific orion amp it reccomended for that (probably the HCAA model) config. I bet you are right, when I went back and looked at the specs it did say the orion 2150 GX was only good down to 4 ohms in stereo. I called my brother and had "the talk" (LoL) about not putting this amp under that type of load. Of course he told me the guy at the sound shop said it could handle 2 ohms and that orion under rates their amps. He also had an interesting story about the first time he had the amp repaired under warranty. He said orion sent a note back recommending that he run another battery in parallel to help support the power demand, he had also complained about engine noise and they soldered that other negative wire to the ground side of the step up voltage side of the transformer. Which orion recommended grounding that wire with the head unit to eliminate engine noise (I'm not sure if I see the benefit in this since it seems like most amp keep the low side and high side grounds of transformers separate).
Kelvin
Old 6th October 2012, 05:15 PM   #43
pergo is offline pergo  Italy
pergo's Avatar
2150GX is min 2ohm stereo or 4ohm mono (with BDG400)
Old 7th October 2012, 02:27 AM   #44
Thanks, my brother said he found the bridge 400 module and also thinks he has the orion crossover part as well, that allows him the option to at least push a 4 ohm sub in bridged mode. With the cross over, bridge and the repaired amp as a package it might increase the value, although after this repair job, I am kind of have a personal connection with it. I may see if he will let me have it and I can incorporate it into my system and show it off. Again, I would like to thank everyone for their help with this. I am now batting 5 for 5 on amp repairs, but I could not have done without leveraging the expertise of you guys.
Kelvin
Orion 2150GX Repair HelpHide this!Advertise here!
Orion 2150GX power draw Dr Zeus Car Audio 4 27th June 2011 02:59 AM
Orion NT Repair AcuraTLSQ Car Audio 0 29th March 2011 12:22 PM
Help with Orion amp repair allorion Car Audio 13 16th September 2010 11:06 PM
Orion 2150gx gain control problem CBR Car Audio 1 11th March 2010 09:15 PM
Repair Help on Orion 2500d wccoug21 Car Audio 28 13th January 2010 03:25 AM
