Diablo Audio
Diablo Audio
Old 23rd September 2012, 10:50 PM   #1
oldguyoklahoma is offline oldguyoklahoma  United States
Default Diablo Audio
Has anyone worked on a diablo 2500.1 replaced all power supply fets. relayes power but power supply wont power up. no rail voltage. any ideas.
Was a nasty melt down. trying to fix for a fiend.
Old 24th September 2012, 12:42 PM   #2
brandes.cm is offline brandes.cm  United States
Production model or proto, if it has the heatsink milled with diablo audio... its production and you might just as well trash it.
They are a bad design and will never be stable below 2 ohms.
Ebbcotech is the only person with knowledge of it and you will get a response here and there but never a full answer.
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 24th September 2012, 01:05 PM   #3
Perry Babin is offline Perry Babin  United States
Post a photo of the circuit board.
Old 24th September 2012, 02:49 PM   #4
It's a proto. It took a hard frying. Killed all the power supply fets. Had several burnt traces and lots of burnt resistors. R&R'd the burnt parts now only the relays come on when powered. No rail voltage. Will post a pic when get back home.
Old 24th September 2012, 03:55 PM   #5
I have a proto version on my shelf right now, I can get some values if you need them.
If you could possibly give me the output fet locations. I need to know where the n-channel parts go and the p-channel. Don't ask why.
Old 1st October 2012, 11:33 AM   #6
Here are some pics of that amp.
Old 4th October 2012, 04:59 PM   #7
What are the parts in the yellow boxes, IRF240 and IRF9240? Which ones belong in each location?
Old 7th October 2012, 01:28 AM   #8
going from the inputs toward the power supply. 4-irfp240 and 4-irfp9240.
Starting to feel like i cant fix anything. this one and three others are kickin my butt.
Old 7th October 2012, 01:59 AM   #9
blazer40 is offline blazer40  United States
Start with the basics.. Is there power on the power supply IC? Can you list the voltages of each pin for us? (I know, this is a Perry question normally.....) Do you have a scope?
-Blazer40
Old 7th October 2012, 02:37 AM   #10
yes. its a old one but works.
Diablo AudioHide this!Advertise here!
el cheapo diablo t line unsimmed experiment mondogenerator Full Range 13 3rd June 2012 03:34 PM
Diablo 2500.1 output driver card brandes.cm Car Audio 6 14th May 2012 12:44 AM
Blown Diablo Prototype Repair DIY help please Drsnazzy Car Audio 8 15th December 2011 08:05 PM
Good books or videos on audio production, audio engineering, or audio editing tunks14 Everything Else 0 15th April 2011 10:00 PM
Help w/ Diablo 5000 amp Tom7227 Class D 0 27th December 2009 08:15 PM
