Go Back   Home > Forums > General Interest > Car Audio
Old 5th November 2012, 02:16 AM   #41
The meter was set to diode check and the pos lead was on batt+ and neg lead was on ground for one test and showed0.000 volts. The first test was to check the fets and pos lead to drain and neg to source of the fets and they all showed 0.000 volts.
So I began pulling the fets off. I rechecked when they were off and checked .470 volts to .490 volts on all.
Old 5th November 2012, 06:21 AM   #42
Did you check for solder bridges?
If it has reverse protection diodes, you'll need to check those.
el cheapo diablo t line unsimmed experiment mondogenerator Full Range 13 3rd June 2012 03:34 PM
Diablo 2500.1 output driver card brandes.cm Car Audio 6 14th May 2012 12:44 AM
Blown Diablo Prototype Repair DIY help please Drsnazzy Car Audio 8 15th December 2011 08:05 PM
Good books or videos on audio production, audio engineering, or audio editing tunks14 Everything Else 0 15th April 2011 10:00 PM
Help w/ Diablo 5000 amp Tom7227 Class D 0 27th December 2009 08:15 PM
Page generated in 0.08046 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
