Hifonics XX Hercules
Old 16th October 2012, 11:38 AM   #21
blazer40 is offline blazer40  United States
Which schematics are you guys referring to?
Old 16th October 2012, 11:55 AM   #22
brandes.cm is offline brandes.cm  United States
SPL ext2000d
Sent from my DROID BIONIC
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 16th October 2012, 12:02 PM   #23
Mind emailing me a copy?
Old 16th October 2012, 12:28 PM   #24
Send a request to brandes.cm@Gmail.com
Old 16th October 2012, 11:45 PM   #25
The -12V regulator was reading -15V, replaced that, voltage is fine. That was the only issue. The triangle wave form on Pin1 of the TL072 is still messed up.
Output waveform, with no input signal
Roughly 250hz
Old 17th October 2012, 02:04 AM   #26
Found a resistor that was out of tolerance, seems to have fixed the issue. Need to test under load.
Old 17th October 2012, 08:40 AM   #27
Perry Babin is offline Perry Babin  United States
Post a photo or the circuit board designation of the resistor. It may help someone else in the future.
Old 17th October 2012, 11:35 AM   #28
R24 was the resistor, was reading 15k ohms.
Is there any way to bypass the secondary board with the controls on it. I believe it has an issue. My waveform starts to get noise at the peak without much gain.
Old 17th October 2012, 11:58 AM   #29
I would think that you could bypass it by jumping the similar colored wires for the shielded cables in the harness.
Old 30th October 2012, 02:29 AM   #30
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
noobies question moved to here --> Help With Gen XX Hifonics Hercules other posts regarding the move deleted.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Hifonics XX HerculesHide this!Advertise here!
Hifonics XX Chaos mike49504 Car Audio 1 3rd September 2011 05:08 AM
Hifonics XX Chaos mike49504 Car Audio 35 23rd July 2011 06:06 AM
Hifonics Hercules VII mike49504 Car Audio 1 10th June 2011 04:41 PM
Hifonics hercules xi mike49504 Car Audio 12 9th January 2010 06:59 PM
hifonics colossus xx mike49504 Car Audio 7 28th November 2008 11:15 PM
