Closest thing I found was the FDP2552, which has the same voltage/amperage rating, but the on-resistance is lower.
the biggest issue is the gate charge is nearly half of the old one, and the gate capacitance is lower. So that means i would have to change all the outputs, and would the drivers handle it?
I don't honestly remember because this thread is a little bit old. Also I no longer work for the company that I was doing these repairs for.
I had fairly good results using irf3710z and swapping the 47 ohm resistors to 68 ohm. Could probably have left the original 47 ohm in but when I originally tried using the irf3415 it ran hot at idle so I swapped resistors around a few times trying to get the 3415's to run cooler...
