Go Back   Home > Forums > General Interest > Car Audio
Old 29th September 2012, 08:16 AM   #51
seankane's Avatar
No 47.5 ohms
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 29th September 2012, 08:18 AM   #52
What is R2 marked?
Old 29th September 2012, 08:19 AM   #53
seankane's Avatar
470=47 ohms
Old 29th September 2012, 08:21 AM   #54
OK. It's 10 ohms on both diagrams.
Post the DC voltage on all pins of U201.
Old 29th September 2012, 08:45 AM   #55
seankane's Avatar
[QUOTE=Perry Babin;3182707]Post the DC voltage on all pins of U201.
Pin 1: -16.40
Pin 2: -8.13
Pin 3: 0.058
Pin 4: -18.16
Pin 5: 0.058
Pin 6: -17.05
Pin 7: -17.07
Pin 8:-17.98
Old 29th September 2012, 08:52 AM   #56
Are you sure that pin 8 is negative?
Old 29th September 2012, 09:03 AM   #57
seankane's Avatar
very sure it is negative thats
what the meter says
Old 29th September 2012, 09:04 AM   #58
Determine why it doesn't have +15 like the other op-amps.
Old 29th September 2012, 09:10 AM   #59
seankane's Avatar
Because R19 is burned in half a 47 ohm resistor maybe? As soon as I replaced R19 and powered up the amp it instantly burned in half again.
Old 29th September 2012, 09:34 AM   #60
seankane's Avatar
I found R19 burned in half because the op-amp was sending negative voltage meeting positive voltage at the other side of R19 which supplies the op-amp with positive voltage. Thus burning it in half. Faulty op-amp.
Does this make sense?
Rockford Fosgate Punch 150S RiLoWa Car Audio 2 29th April 2012 02:55 AM
Rockford Fosgate Punch 75HD seankane Car Audio 5 18th July 2011 12:49 AM
Rockford Fosgate Punch 200a4 chipper Car Audio 7 26th March 2011 03:01 AM
rockford fosgate punch z stevena2006 Car Audio 2 23rd December 2009 04:20 PM
Blown Rockford Fosgate 250M, help a newb =-) mkfosgate Car Audio 11 26th July 2009 07:23 PM
Page generated in 0.19571 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
