Go Back   Home > Forums > General Interest > Car Audio
Old 29th September 2012, 07:30 AM   #41
10,000 ohms.
Old 29th September 2012, 07:36 AM   #42
I found another diagram (punch 250.1) that has the resistors (190 and 191). They appear to go the telco jack. They probably drive some sort of display.
Old 29th September 2012, 07:38 AM   #43
seankane's Avatar
Yes the PSD-1 punch status display. It displayed power, thermal, clipping, max, and signal.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 29th September 2012, 07:53 AM   #44
seankane's Avatar
Still have no output with the switch in the l+r position only when I switch it to (L)mono position and I hear a buzzing on the board.
Old 29th September 2012, 07:56 AM   #45
seankane's Avatar
The amp plays clean sound in full range to a speaker in the (L) mono position but when you switch it a huge "POP" and a bit of current draw???
Old 29th September 2012, 07:59 AM   #46
Do you always have a good signal on pins 1 and 7 of U102?
Old 29th September 2012, 08:03 AM   #47
seankane's Avatar
Only in the (L) mono position and its a little hazy, when I switch to L+R I get -15.76 vdc on pin 1 and 7 and no outout.
Old 29th September 2012, 08:07 AM   #48
Check the output pins of the rest of the op-amps. Do any have significant DC on them?
Old 29th September 2012, 08:12 AM   #49
seankane's Avatar
U201 has -16.50 vdc on both output either position
Old 29th September 2012, 08:15 AM   #50
Do you read 10 ohms between the left and right RCA shields (no RCAs plugged in)?
Rockford Fosgate Punch 150S RiLoWa Car Audio 2 29th April 2012 02:55 AM
Rockford Fosgate Punch 75HD seankane Car Audio 5 18th July 2011 12:49 AM
Rockford Fosgate Punch 200a4 chipper Car Audio 7 26th March 2011 03:01 AM
rockford fosgate punch z stevena2006 Car Audio 2 23rd December 2009 04:20 PM
Blown Rockford Fosgate 250M, help a newb =-) mkfosgate Car Audio 11 26th July 2009 07:23 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
