Go Back   Home > Forums > General Interest > Car Audio
Old 28th September 2012, 06:18 PM   #21
seankane's Avatar
C108: -0.064 vdc
C110: -15.41 vdc
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 28th September 2012, 06:29 PM   #22
Post the DC voltage on all pins of U102.
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Old 28th September 2012, 07:14 PM   #23
seankane's Avatar
[QUOTE=Perry Babin;3182707]Post the DC voltage on all pins of U102.
Pin 1: -15.47
Pin 2: -9.74
Pin 3: -9.74
Pin 4: -17.41
Pin 5: -9.46
Pin 6: -9.46
Pin 7: -15.02
Pin 8: +27.08
Old 28th September 2012, 07:29 PM   #24
What is the DC voltage on the RCA shield?
Make sure that the shield connections are intact.
Old 28th September 2012, 07:38 PM   #25
seankane's Avatar
0.013 vdc
Old 28th September 2012, 07:45 PM   #26
Find R115. Do you have -10v on one end and 0v on the other end of it?
Old 29th September 2012, 03:51 AM   #27
seankane's Avatar
yes
Old 29th September 2012, 05:35 AM   #28
Check the components around Q12 (the +15v regulator). If they're within tolerance, post the voltage on all 3 legs of that regulator.
Old 29th September 2012, 06:19 AM   #29
seankane's Avatar
R33 was out of tolerance i changed it.
The regulator reads as follows:
Vin: 29.24
Vout: 17.53
adj: 16.27
Old 29th September 2012, 06:30 AM   #30
With all of the components in the circuit, do you still have DC offset on the outputs?
Rockford Fosgate Punch 150S RiLoWa Car Audio 2 29th April 2012 02:55 AM
Rockford Fosgate Punch 75HD seankane Car Audio 5 18th July 2011 12:49 AM
Rockford Fosgate Punch 200a4 chipper Car Audio 7 26th March 2011 03:01 AM
rockford fosgate punch z stevena2006 Car Audio 2 23rd December 2009 04:20 PM
Blown Rockford Fosgate 250M, help a newb =-) mkfosgate Car Audio 11 26th July 2009 07:23 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
